1 - 3 of 3 Posts
CES light is on so I had the fault codes that I got on my Peake verified at the shop I use for stuff I can't/won't do.
The codes at the service guy point to "exhaust-gas temperature sensor" and "camshaft position sensor" which may be the same as pulse generator.
I can't find part numbers on realoem.com and need some help. Anyone have any ideas or access to the part numbers? The codes are 079 and 010 (Peak Codes are 0A and 4F). Both code sources point to the same thing.
Thanks in advance.
19,585 Miles
Thanks in advance.
There is a intake and exhaust cam shaft sensor.
http://www.realoem.com/bmw/partgrp.do?model=CN93&mospid=48090&hg=12&fg=05
Discussion Starter · #3 ·
Thank you Ron.
1 - 3 of 3 Posts
