Thank you. I reinstalled the programm already and also not asked after a PIN? Strange. Actually I noticed no faults in car, thank god! I can post/send also the log from coding day if this can be helpful. I have also the CAF-File (backup) from folder DATA\CAF.
Here is a part of LOG-File, many data, but maybe a hint to the fault (VIN deleted by myself):
Timestamp: Tue Jul 05 20:53:27 CEST 2016
ErrorCategory: SYSTEM_ERROR ID: 2130759743
Class: com.bmw.psdz.vehicle.connection.util.ResultUtil
ExecutionContext={category=TAL, ecuid=(FEM_BODY,0x40), TA_CATEGORY=cdDeploy, PROGRAMMING_STATUS=finalizeECUCoding,PSdZEvent={message=MCDDiagService<id=230900, job=com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, service=DSC - DiagnosticSessionControl, description=error: timeout, link=Physical request to ECU with address 0x40>, timestamp=Tue Jul 05 20:53:27 CEST 2016, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null},PSdZEvent={message=MCDDiagService<id=230900, job=com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, service=DSC - DiagnosticSessionControl, description=error: timeout, link=Physical request to ECU with address 0x40>, timestamp=Tue Jul 05 20:53:27 CEST 2016, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null},PSdZEvent={message=MCDDiagService<id=230900, job=com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, service=DSC - DiagnosticSessionControl, description=error: timeout, link=Physical request to ECU with address 0x40>, timestamp=Tue Jul 05 20:53:27 CEST 2016, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null},PSdZEvent={message=MCDDiagService<id=36900, job=com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, service=RDBI_ADS - ReadDataByIdentifier ActiveDiagnosticSession, description=error: timeout, link=Physical request to ECU with address 0x40>, timestamp=Tue Jul 05 20:53:27 CEST 2016, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null}}MCD Error Code: 0xd03fMCD Error Code Description: Module offlineVendor Code: 0x4e47Vendor Code Description: link is no longer active
at com.bmw.psdz.vehicle.connection.util.ResultUtil.checkResponsePositive(ResultUtil.java:77)
at com.bmw.psdz.vehicle.connection.util.ResultUtil.getPositiveResponseOrTerminateOnError(ResultUtil.java:177)
at com.bmw.psdz.vehicle.connection.wrapper.LegacyJobWrapper.terminateOnError(LegacyJobWrapper.java:649)
at com.bmw.psdz.programmer.facade.ProgrammerImpl.finalizeECUCoding(ProgrammerImpl.java:901)
at com.bmw.psdz.talexecutor.tasks.CodingTask$Finalization.doExecute(CodingTask.java:197)
at com.bmw.psdz.tasks.base.TaskStep.execute(TaskStep.java:119)
at com.bmw.psdz.tasks.base.SingleEcuTask.executeFinalization(SingleEcuTask.java:841)
at com.bmw.psdz.tasks.base.SingleEcuTask.execute(SingleEcuTask.java:506)
at com.bmw.psdz.tasks.base.scheduler.RunnableTask.run(RunnableTask.java:212)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:744)
16-07-05 20:53:27,687 [TRACE] [] com.bmw.psdz.system.configuration.languagemapper.LanguageMapperImpl: Custom language mapping to language 'deu' was not successful, using 'eng' as default instead. [com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread]
16-07-05 20:53:27,687 [TRACE] [CodingTask - vin:xxx- ecu:FEM_BODY - da:0x40] com.bmw.psdz.vehicle.connection.wrapper.LinkPool: closeECUConnection started [ParallelTask-6]
16-07-05 20:53:27,687 [TRACE] [] com.bmw.psdz.system.configuration.languagemapper.LanguageMapperImpl: Error: Language Mapper could neither map error id '2130759743' to intended language 'deu' nor default language 'eng'. Returning empty string instead. [com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread]
16-07-05 20:53:27,687 [DEBUG] [CodingTask - vin:xxx- ecu:FEM_BODY - da:0x40] com.bmw.psdz.vehicle.connection.wrapper.LinkPool: detaching from logical link FEM_BODY_40_ETHERNET use count = 0 [ParallelTask-6]
16-07-05 20:53:27,687 [DEEP_TRACE] [CodingTask - vin:xxx - ecu:FEM_BODY - da:0x40] com.bmw.psdz.vehicle.connection.wrapper.ConfiguredDProject: execute stopCom on logicalLink FEM_BODY_40_ETHERNET [ParallelTask-6]
16-07-05 20:53:27,687 [DEBUG] [CodingTask - vin:xxx - ecu:FEM_BODY - da:0x40] com.bmw.psdz.vehicle.connection.wrapper.ConfiguredDProject: trying to remove logical link FEM_BODY_40_ETHERNET from project [ParallelTask-6]
16-07-05 20:53:27,687 [TRACE] [] com.bmw.psdz.system.configuration.languagemapper.LanguageMapperImpl: Custom language mapping to language 'eng' was not successful, using 'eng' as default instead. [com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread]
16-07-05 20:53:27,687 [INFO] [CodingTask - vin:xxx - ecu:FEM_BODY - da:0x40] com.bmw.prodias.execution.DefaultJobProcessor: logical link FEM_BODY_40_ETHERNET is not cleanly removable, but will remove (and reset) it anyway [ParallelTask-6]
16-07-05 20:53:27,687 [TRACE] [] com.bmw.psdz.system.configuration.languagemapper.LanguageMapperImpl: Error: Language Mapper could neither map error id '2130759743' to intended language 'eng' nor default language 'eng'. Returning empty string instead. [com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread]
16-07-05 20:53:27,687 [DEBUG] [CodingTask - vin:xxx - ecu:FEM_BODY - da:0x40] com.bmw.psdz.vehicle.connection.wrapper.ConfiguredDProject: successfully removed logical link [ParallelTask-6]
16-07-05 20:53:27,687 [WARN] [] com.bmw.esys.commons.exception.EsysExceptionHandler: PSdZ Error -- Exception in executeAsync. [C046] --- [Ljava.lang.String;@1410b3a [com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread]
com.bmw.esys.domain.psdz.PsdzException: Exception in executeAsync. [C046]
at com.bmw.esys.domain.psdz.PsdzEventExceptionListener.onException(PsdzEventExceptionListener.java:170)
at com.bmw.esys.domain.psdz.PsdzEventExceptionListener.eventReceived(PsdzEventExceptionListener.java:83)
at com.bmw.psdz.uc.event.RegisteredEventListener.eventReceived(RegisteredEventListener.java:59)
at com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread.notifyListeners(ExternalSynchronizedHandler.java:140)
at com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread.run(ExternalSynchronizedHandler.java:126)
Caused by: negative response error:
code: the result contains an error
description: Service DSC has error in result: [Severity=2051][ErrorCode=53311][ErrorCodeDescription=Module offline][VendorCode=20039][VendorCodeDescription=link is no longer active]; ECU: FEM_BODY_40_ETHERNET
severity: ERROR
