I took it in and they ran a diagnostic which apparently told them that the final stage unit is okay but they said to get the A/C levels checked and pressure tested. I did this and found out is was low on fluid but there were no leaks. The A/c unit now blows out cold air but the fan speed problem still exists.
After checking this site I see that others have had this same problem which was fixed by the final stage unit being replaced. My repair shop is telling me that it is the main control unit that is gone. This is a $1,000+ repair as the unit comes as one piece.
My question to those that have had this problem is - 'does the final stage unit defect show up where a diagnostic is run? Or is this something you just have to replace to discover if it is the problem?' I would much rather change this unit for a $100 instead of spending a $1,000.
Advice would be highly appreciated.
