Toe in-Toe Out: Toe in means your wheels, when viewed from above, points towards each other on the front. Toe out is the opposite.robg said:
Camber: Camber is affected when you lower your car. The lower the suspension travel, the more the wheel will tend to bow out on the bottom and point in on the top. That's Negative Camber. When you put your car up on a jack, or when the car is lifted off the ground and the suspension is free to travel, the bottom of the wheel tend to point in and the top of the wheel tend to point out, that's positive camber.
Learned all this from playing Grand Turismo 3.
