1 - 8 of 8 Posts
Investigative Tinkerer
Here is the first of a couple of projects that I wanted to get done before the big party down south.
This is a video camera mount that I made a better bracket for.
I didn't care for the stamped steel one that came with such an excelent quality gimbal.
The rollhoop was salvaged from a rolled M Rdstr, so no flames for cutting away the foam padding (what a ***** to get that stuff off).
Notice the abrasions on the top of the hoop...
Ouch!
Discussion Starter · #2 ·
Another shot of the video mount
Obviously, this shot was prior to fitting the hoop in the car.
Discussion Starter · #3 ·
Lightened Strong Strut
I just got this back from the powder coating shop today.
Thirteen equally spaced 1.0" holes.
The countersinking makes them appear larger.
I am pleased with the results, even though only 1.5 Lbs were saved from the original strut that had only six holes (2ea. 1.0", .75" & .50").
Discussion Starter · #5 ·
Any plans to powder coat the camera mount?
Yes...
Or something. Either anodizing or powder coating in a low gloss/satin black.
It does tend to stick out too much in raw aluminum;)
Discussion Starter · #8 ·
Want to get fancy you could duplicate the bar shape and it would blend right in.
Originally, I wanted to machine the clamp to fit over the foam padding, with just a few thousandths crush.
After making templates of the foam's shape, for the length required, I determined that it was way beyond my capabilities as a machinist.
Besides the strange shape of the padding, it is also tapered as it rises towards the top of the bar...
It was easier to trash a hoop from a wrecked car
Good idea about the delrin though, use black (carbon impregnated) and you solve the coating problem.
1 - 8 of 8 Posts
