1 - 1 of 1 Posts
Jan
Good day.
Background:
I had a cracked Valve cover, got a replacement valve cover. The Breather was leaking and the replacement is on it's way.
In the process of moving the vehicle I had a fire above the starter on the firewall / heat protection (see attached photos). I don't know what is behind the padding ( I assume it is called the firewall :cry:
There is also a sign of burning on the I assume it is the Heat Sensor
We killed the fire with water, which was the closest and could reach the more difficult firewall
Obviously, the Dashboard shows a big Yellow Warning sign.
The fire lasted for about 5 min
We disconnected the battery, and dismantled to see to the point that we are now
My questions are:
  1. Do I have to take off the covering of the firewall
  2. What could be damaged behind the firewall
  3. Is it the Engine heat sensor electrical fitting being damaged?
  4. Removal of starter for checkup
  5. Anything else to look for?
Kind regards
Jan van Niekerk
Souh Affrica:cry:
1 - 1 of 1 Posts
