1 - 3 of 3 Posts
Hi all I'm new here so any help would be awesome........ My 02 X5 4.4 has done 315000 kms and has a problem with the battery if I don't use it over the weekend 2days, Monday morning it's dead flat.
It's a new battery only 3mths old, has anyone else had this problem?
Cheers
Nuclear engineer
02/2012 X5 35d M57Y CPO 105K miles NOKIAN WR G3 20K miles
Batteries are not usually maintained or charged after manufacture, and with a nominal 1% self-discharge rate, a hundred days later they are dead dead dead.
You BMW will NEVER EVER fully charge its battery 100%.
Buy a SMART-CHARGER such as recommended by BMW and charge the battery regularly and frequently.
you either have a bad cell in the new battery
...even low water will cause that
or
a power drain in the vehicle
have the battery replaced if you suspect it's just that
if...
you replaced the old battery for the same or similar reason
the suspicion would be on the vehicles electronics
1 - 3 of 3 Posts
