1 - 2 of 2 Posts
Is anyone else having this problem. I have had three flats in the last two months, and it's really starting to get annoying. Is this normal or am I just unlucky. There is a ton of construction, that might have something to do with it. But three, that's unheard of.
Home construction is worse than commercial
We built a house and yes we had this problem of flat tires!
The problem is residential construction is worse than commercial because res construction uses alot of nails screws and there is less regulation on cleanup.
Stay away from construction sites, if you can. Otherwise, drive very slowly through it because nail/screw, if on the road, have less ability to penetrate at low speed than high speed.
1 - 2 of 2 Posts
