1 - 4 of 4 Posts
Hello folks recently I brought a descent floor jack and stands to work safetly under my car, lifting the rear of the car is straight foward, I place the jack under the Diff.
But where do I position the jack to raise the front of the car ? , it does have a plastic cover underneath, I dont want to do any damage by lifting the car in the wrong place.
Regard: Owen
Cogito Ergo Zoom
If you have the aluminum stiffener plate under your engine, put the jack under the raised rectangular spot near the back of it. If your car is too low to get the jack in there you'll need to use the scissor jack in the trunk to lift one of the front jacking points to gain enough height. No need to remove plastic plate before lifting, it's not in the way.
OP-
Please note that the various write ups do not recommend jacking the rear by the differential. The suggested jack point in the rear is the subframe directly forward of the differential that is in the shape of a U.
Also note that I am a new owner and knowledge is not experience based, yet. :)
-g
1 - 4 of 4 Posts
