Try & see if you can check the antennas in INPA, you will probably get a better pic of what the signal range should be?Finally made it here. Ran ECU function tests for the CCC-ANT ECU. Arial Self Test says faulty (first test), does this refer to the DA?
UPDATE: Ran same test on E60, it also says faulty Aerial self test. FM sounds fantastic in my E60. Maybe this is something else.
