A few weeks ago, I posted this question about overfilling ATF here: http://www.bimmerfest.com/forums/showthread.php?t=587189&highlight=overfilling+atf
After reading the responses, I wasn't too worried but still did not feel entirely comfortable as the car sounded different as well as drove a little different (better). So I contacted gtxragtop (Dave) to see what he thought as he has done a lot of research on these ZF trannys. He cautioned about overfilling. So I decided to do another drain. I put the car up and drained per the instructions. I had the car tilted about 1" higher in the rear when measuring at the jackpoints, based on Dave's previous experience (he used a 2" tilt). Like him, I'd rather fill a little higher than lower. I was a little more than a pint high. So no big deal, I capped it up and went for a test drive. The car is noticeably quieter. The shifts are every bit as smooth but the car is somehow quieter. I have no clue why but now I am wondering if I possibly did any damage while driving with excess ATF (about 1,500 miles, mostly highway) :dunno:. Anyway, just wanted to let folks know that if their engine/tranny sounds louder after an ATF drain & fill, it is likely you are running a little high and you should drain some off.
