Bmw Bimmerfest Homelink Range References:
So all benefit from this effort, here are summaries of RELATED links.
Note:
- Most Homelink posts on Bimmerfest are about PROGRAMMING & CHOICES.
- The summarized posts below are about RANGE & (INSTALLATION) TESTING.
- All Bimmerfest-quoted homelink URLs failed to work properly.
- Therefore there are no Bimmerfest-suggested Homelink URLs quoted below.
TITLE: 3-Series -> E46 (1999 - current) -> homelink short range?
LINK:
http://www.bimmerfest.com/forums/showthread.php?t=94493
- BMW Homelink range is too short (100 feet).
- Radio interference affects the BMW Homelink GDO range.
- The chin trick shows up again in this posting.
- The Homelink free antenna range extender repair worked only marginally.
- Extended range fix is no longer offered by Homelink for BMW automobiles.
- The angle that you hold the transmitter to the car's homelink when
- programming has an effect on the Homelink GDO signal strength output.
- Homelink "clones" the signal of the remote you're trying to program.
- So, weak original remote, weaker homelink signal.
- You can make your own "upgrade" with a piece of foil wrapped around.
- Thank you for visiting our HomeLink website and for your inquiry.
- Unfortunately we do not offer that external fix any longer.
- All new Homelink system for BMW (since 2001) have had that
- [range extending] device [already] implemented into the unit.
- I have a few suggestions you might try to help with the issue
- you are having with your Homelink and garage door opener.
- Put a new battery in your hand-held transmitter.
- Training the HomeLink system takes more power from the battery
- than when you push the button to open the door.
- Sometimes by putting a new battery in the hand-held transmitter, will
- send a stronger signal and increases the range on the hand held transmitter.
- Retrain the HomeLink at different lengths and angles.
- Start by holding the hand-held transmitter 3-4 inches away then 5-6,
- even 6-8 inches from the buttons.
- Try a second hand held transmitter with new batteries.
- Straighten the antenna wire that hangs down from the garage door
- opener motorhead in the garage.
-Try programming all 3 HomeLink buttons.
TITLE: Step by step installation & test of BMW Homelink universal tranceiver.
LINK:
http://www.bmwnation.com/ARTICLES/diy/bmwut/bmwut.html
- They show how to obtain & install & test a homelink GDO in a BMW.
- But, their test is only electrical power; not range & offset.
TITLE: Bimmerfest -> 3-Series -> Finally, bot Universal Transceiver
LINK:
http://www.bimmerfest.com/forums/showthread.php?t=9524
- Homelink used to provide a BOOSTER KIT for BMW owners.
- Some BMWs are shielded so that's why a Homelinink Booster Kit is needed.
- Homelink only plays back the signal you gave it (garbage in; garbage out).
- Use a fresh battery in your remote to give Homelink the strongest signal!
TITLE: Homemade super range extender
LINK:
http://bmwtips.com/tipsntricks/Homemade%20super%20range%20extender%20here!_files/UGDOrangeextender.htm
- Increases range of Homelink GDO 300% (claimed) by modifying its antenna.
TITLE: Bimmerfest -> 3-Series --> Universal Transmitter
LINK:
http://www.bimmerfest.com/forums/showthread.php?t=10940
- Homelink range is over 100 feet.
- Battery strength of the remote programmer is a key component of range.
TITLE: General BMW -> Anyone with Homelink? Thoughts?
LINK:
http://www.bimmerfest.com/forums/showthread.php?t=47262
- The Homelink receiver is just an X10 unit (dirt cheap & easily found).
- Drawback is VERY short range; range-extending addon is available.
- First program with a fresh battery in the remote.
- Improves range more than half a block away and around a hill.
- Range is over 300 feet with an "improved" replacement from Homelink.
TITLE: The Best of Bimmerfest! -> Do-It-Yourself H.Q. -> Home-made Homelink
LINK:
http://www.bimmerfest.com/forums/showthread.php?t=13660
- Install your actual REMOTE in the spot for the BMW homelink system
TITLE: BMW Model Discussions -> 3-Series -> Hard to Install Homelink?
LINK:
http://www.bimmerfest.com/forums/showthread.php?t=34649
- Steps on installing your own BMW Homelink universal transceiver.
TITLE: General BMW -> Universal Transceiver
LINK:
http://www.bimmerfest.com/forums/showthread.php?t=55190
- Dismal range improved by a new unit from Homelink (now range is 200 feet).
- Installed free of charge at the BMW dealership.
- One user got a range on Homelink better than the range from Genie.
- Range on Genie is half a block; range on BMW homelink is near zero.
- Upgrade antenna kit from Homelink will fix the range problem.
- BMW Homelink range is 150 feet by another user.
TITLE: 3-Series -> universal garage opener
LINK:
http://www.bimmerfest.com/forums/showthread.php?t=12259
- Install an actual remote in the place of the BMW headliner Homelink.
- USA 390 Mhz (Europe 433.93 Mhz); European lower power;range five meters.
