1 - 1 of 1 Posts
Nomad
Ok well i went around changing my oil, took off the filter, took out the plug. OH MY GOD was my oil overdue for an oil change it was pure black!!! Not only after i changed it did it run smoother, i believe it got a increase in power, back closer to stock.
Well i went to the specialist and we adjusted my tps, it turns out when your car goes from 800-1500 rpms constantly it's your O2 sensor, he said he must have mixed it up with a vw engine or something, but if it only does it on random times, you can unhook your o2 sensor while it's running if that's what it is doing, you either need to clean it out or buy a new one. I didn't have time to fix it so i will leave an update when i do. Also he said one guy brought in a e30 today and the timing belt broke, every valve, the cam, and 3 pistons all went to ****. Just another reason to replace it
1 - 1 of 1 Posts
