1 - 7 of 7 Posts
· Registered
What have your results been?
I used it on both my car, the BMW, and my Wife's Benz. Both sets of wheels still seemed to get loaded with brake dust, and it didn't seem to come off any eaiser....
What did you experience?
· King of Rear Clunks
I used it for the first time yesterday so I really can't say yet. I wonder if the amount sprayed makes a difference. I used very little.
· Parking Spot Maven
I have used it for the last two weeks (daily when I clean them) and even did one side and not the other and then switched sides (in case I brake more while turning one way than the other) to test how it was working.
I don't remember Marco claiming that the spray would repel brake dust. In fact, in my experience a sprayed wheel will actually collect a little more dust than an unsprayed one. But the dust slides right off on a sprayed wheel. In fact, when I use it in conjunction with the Meguiar's wheel cleaner I bought, I don't even have to touch the wheels to get the dirt off except to dry them (and then again to get the rust that sheds off the rotors after I drive it 300 feet :mad: ). But in-between washes I use either Meguiar's detail spray or Zaino detail spray and they wipe clean quite easily. Maybe this has something to do with the fact that I clean them daily?
If I spray a wheel heavily, it seems to collect substantially more dust than an unsprayed wheel. If I spray it really light (maybe 2 seconds a wheel or so) it works great. Maybe you could try misting each wheel lightly next time and see what happens. :dunno:
I haven't had the spray in a few days - I think I left it outside of my garage and somebody threw it away or something. I need to go back and get some more!
As an aside, I have found that the spray does mask some of the gloss on the wheels and gives them a 'soft' look instead of shiney. I wouldn't use it if I were showing my car.
My two cents. :D
--SONET
· Registered
Discussion Starter · #4 ·
Sonet,
Thanks for the write up. I guess I thought it would repel the brake dust and keep the wheels looking cleaner longer...
Regarding wheel cleaners and rusting rotors. I was using the Meguires wheel cleaner and switched to Griot's Garage wheel cleaner. Seems like I would use less cleaner, get better results and the rotors had minimal rust.
I also noticed the shine on the wheels was knocked down when I used the detail spray. I'll keep using it, but wanted to see what everyone else's experience was.
See ya
Chipster
Thanks for the info on the wheel cleaner Chip.
I'm now stuck with 4 gallons (1 gallon of 4:1 concentrate) of the Meguiars cleaner, but I try Griot's after I'm through this stuff.
--SONET
· Registered
I waxed my wheels last weekend, and after a week of hard driving they were gunmetal gray again. :cry: So, I took the hose and washing brush. Voila! The wheels were super-clean again, without any kind of soap or scrubbing. :thumb:
· into things retro
Some follow up
Okay guys, here's my experience so far with the In n Out Detail spray:
At the detail clinic, Marco did my left front wheel as a demo. The other 3 wheels were left unsprayed. Since I only drive the car a couple of times a month and wipe down to cover after each time out, I have not re-washed the car yet. I had the car out the other day for the third time since the clinic and the left front wheel still requires a lot less effort to wipe the dust off! :)
I agree with SONETs assessment. I think the spray is a good (quick) way to may the wheels easier to wipe brake dust off of in between washes. I would not spray on before a show (although on my wheels, due to the 'shadow' paint finish, the spray does not adversely affect the appearance).
After the last wipe down, I sprayed all 4 wheels (again, it must be noted, quickly and lightly) and I'll see how things go the next few times around.
1 - 7 of 7 Posts
