Status
Not open for further replies.
2,221 - 2,240 of 3,266 Posts
Save
Hi Shawn,
What will happen if I click code at SVT?
You will VO Code entire car (all ECU's), and if you do this, make damn sure the motor is NOT running, else you will crash DME CAFD.
Save
Newbie here. I'm trying to Edit FDL and get "The chosen EST "C:\EC-Apps\EGS\E-Sys\lib\environment\Data\FreeToken.est is no Existing File. [C156]" What do I need to fix?
Did you use E-Sys launcher to Open E-Sys or did you open E-Sys directly?
Save
hi shawn,
new to coding and just ordered an enet cable from April1.
To get a head start on this can you help me out on links for the software I'll need and the coding cheatsheet for an 2014 F12?
First things I'd like to code are to disable Active Sound Design (ASD) and disable warning messages.
Also has anyone heard of coding one-touch convertible top operation from the button like the windows?
thanks again! - these forums are a great source of information!
hi shawn,
PM sent.
Save
What coding can be done on a F26 X4 28i?
Coding possibilities depend on specific car factory options and installed hardware, and they are too numerous too list. If you have specific questions, you should ask, but this generic question is both impossible and impractical to answer.
Save
I use E-Sys Launcher. Which brings up another question I have:
In E-Sys Launcher I have the ability to Select F48 Series (which is the car I'm attempting to code) but in E-Sys I'm told to use F56 (Mini) because F48 isn't available. Should I be selecting F56 in the Launcher? Does it matte?
It matters, but this has nothing to do with .EST, and that is correct setup for F048:
E-Sys Launcher Car Series - F048
E-Sys Connection Target = F056
Save
Sorry,I should ask about F26 cheet sheet and I can't search it:dunno:
I have never seen an F26 Specific Cheat Sheet. It's all about the ECU's present and not the actual Chassis. You will likely need to use a combination of cheat sheets (F25, F30, et.c) to code it.
Save
Thanks Shawn!
not sure to post in this thread but a couple questions for you and the forum for coding an F12 M6
On disabling the Active Sound Design (ASD) - i looked it seems might be a few options, such as F021 and F006? What should work best?
Also, have not found anything on the convertible top - is there anyway to code a one-touch open/close operation?
Thanks again!
Thanks Shawn!
Thanks again!
Sorry, I don't know about ASD or Top folding.
It used to be you could code ASD => BAUREIHE = F021 to disable ASD, although I am not sure it works with newer firmware.
Save
Thanks. Not sure what I did but I just went in and reloaded the token and it worked. And I also just completed my first coding: Turned off the legal disclaimer on startup! wooohoo! Now I just need to find better cheat sheets for my car. Finding it hard to follow the cheats I've found so far. Anyone find any good listing for F048?
I use the bmw coding database (www.bmwcodingdatabase.com) which has a good number of coding options. Within the database you need to use the F56 model as the source for the codes for your vehicle. (F45/F46/F48 use similar electronics to the new mini). I have an F45 2Series AT and have changed the disclaimer messages and increased the indicator blinker from the factory set 3 blinks to 5. I tried to add the indicators to the HUD but this doesn't work and looking back through a number of threads here this doesn't work for the F30 either.
Thanks Coding Superstars
I have not posted in awhile, but I need to give thanks to the gentlemen who have dedicated their lives to make coding easy for the rest of us. Thank you - shawnsheridan, tokenmaster and octopump. Without you guys, we would just have plain old BMWs. Thanks again.
:beerchug::beerchug::beerchug:
Status
You have insufficient privileges to reply here.
