Status
Not open for further replies.
Former Coding thread - Closed
779K views 3.3K replies 702 participants last post by  Almaretto
#1 · (Edited by Moderator)
#1,777 ·
The instructions told you to uncheck the Update VCM box under E-Sys Options. You didn't. So now you have this error.
But the error is harmless, and your coding changes were made regardless of it. So if ASS isn't working as coded, the issue is something else.
Save
#1,778 ·
Hi Shawn, I have E-sys 3.23 and psdzdata 50.3 with a Code awayDKF01.est token. I am trying to code my shift paddles to work on my f20, I have changed 205 for 2TB but this didn't activate the paddles. I have seen that I need to code FA into ECUs EGS and GWS to active the S1 -S7 also but in not sure how to go about this exactly. I another post I have also seen it is possible to FDL the shift paddles under 3000 sportsschalter_alt active (could be spelt wrong) but this is where I come unstuck. the pin that I have been given with my e-sys isn't working. can you send me the links to everything I need to complete my task?
Thanks in advance
#1,780 ·
Thanks Shawn, I managed to code the new FA to EGS, however code is greyed out on GWS (there is no cafd in the tree). this has given me S1-S7 however if I manually use the shifter it changes back to M1-M7. also the paddles still not active.
Any suggestions will be greatly appreciated.
#1,781 ·
Not all GWS have CAFD, so unless you deleted yours, this is normal.
I think for F20 / F30 though, Paddles require wiring run to ICM. Did you add the wiring?
Save
#1,784 ·
From what I understand it is, but I have never had to do it myself.
Save
#1,786 ·
Hi Shawn,
We have had our car recalled and replaced so I went to make the same coding changes to the replacement car and I***8217;m getting an couple errors trying to Read Coding Data;
File for "cafd_00000794-014_040_150" not found! [C012]
File for "cafd_000016ee-113_110_015" not found! [C012]
I***8217;m using Esys 3.24.3 and v.56.0 PSdZData could I please get the current version stuff to give that a try?
Many thanks,
Cam.
#1,788 ·
Hi Shawn,
We have had our car recalled and replaced so I went to make the same coding changes to the replacement car and I'm getting an couple errors trying to Read Coding Data;
I'm using Esys 3.24.3 and v.56.0 PSdZData could I please get the current version stuff to give that a try?
Many thanks,
Cam.
PM sent.
Save
#1,790 ·
I don't understand. Why would you not just reply to same PM rather than clutter up forum with a new post, which I may not even see? :confused:
PM sent.
Save
#1,793 ·
Was this COAPI-2041 error solved with the NFRM module?
I have the same error, all modules work without a problem but codierdaten_lesen on NFRM gives me:
2041 Error CDH.C CDHCheckIdent 3
Falscher SG-Codierindex A_PL2FRX: CODIERINDEX = 33h FRM2_E89.C08: CODIERINDEX = 08
2041 Error COAPI2.CPP coapiRunCabd 6
Falscher SG-Codierindex CODIERDATEN_LESEN
NCSExpert: 4.0.1
CoAPI: V3.13.2
KrAPI: 3.0.2
Ediabas: V7.3.0
Downloaded e89 daten files dated 11th april 2014
I am trying to get my folding mirrors with FOB and CA to work again after BMW update.
#1,794 ·
Yesterday i mapped the rear DRL and it works.
no errors that afternoon.
But when i drove to work today, the kombi told me, that the trunk is open, also the pdc doesnt work anymore, just like the rear windows.
the rear DRL still works.
the REM seems to hang.
does it just need a reset or do i need to reflash it?
what would you do?
#1,795 ·
what would you do?
#1,804 · (Edited)
Hey guys. Awesome stuff here as usual. I just picked up an F15, and I need to "update" some stuff, so wondering if anyone can help with software download links? I already ordered the cable and I have an old coding laptop (for when I had E70), so I think I can just update that one?
Cheers!
(Actually I just want to enable Anti-Glare High Beam that we US folks don't have).
#1,807 ·
Coding in SLC, Utah - I get it - Willing to help.
After spending the last several evenings attempting to understand FA, SVT, CAFD, and the related acronyms I finally have a basic understanding of coding. I was able to remove the Start-up Disclaimer, unlock doors at engine shut down, and display TPMS data.
I'm ready to move on to more complex coding for brake force, Lane Change Count, camera zoom, etc.
Thank you Token Master, Shawn, April One and the people who compiled cheat sheets who made customizing our rides relatively easy (after some trial and error).
The best part is my 335i starts with no error codes! :)
BMW SL,UT
Save
#1,808 ·
Hi everyone. I have a 2012 535i xdrive (f10) and wanted to program a few features with esys. Can someone point me in the the right direction of the best cable and software version to use? I think it was this forum that people suggested this is the cable to go with: http://www.ebay.com/itm/OBD2-ENET-E...870&meid=839d2998f94540588ccc4a43555e2ca9&pid=100005&rk=3&rkt=6&sd=231656612013
I also did some digging around the forum and found the f10 cheatsheet as well as some step by step guides for programming with esys. Just want to make sure I got the right stuff and not turn my car into a brick.
Thank you in advance.
Michael
#1,809 ·
Michael
#1,812 ·
Hi Shawn,
I just got 2015 320i. I also have 2015 X5 as well. I need to code both cars.
I need to learn how to code basic things like folding mirrors, unlock all doors on off etc.
Can I use latest e-sys s/w with Integrated Cheat Codes: E-Sys Launcher V2.4.x. Will it have all the codes for both cars?
Please send me the latest PSZdata and e-sys and
Coding Library All PDFs on Instructions/ToDo's etc:-
Coding made easy: Step by step instructions
Download Links to Softwares - for both cars.
Thanks shawnsheridan, appreciate it!!
#1,813 ·
Hi Shawn,
#1,822 ·
54.1? No. 54.1 is now 14 versions old, and we do not deal with old versions. Latest is 56.5.
PM sent.
Save
#1,824 ·
Coding problem with 2016 model
I realize that I don't have a real BMW but I hope for some clues nonetheless. :)
I have a 2016 MINI 2-door that I'm trying to code. I successfully downloaded Esys Launcher Premium (with TokenMaster) and PSdZData Lite v.55.4.
I can connect to my car; read & activate an FA; read the ECU; and find the 'green-checked' CAFD parameters. But, when I expand any of the parameters and click Read Coding Data, I always get a File for "cafd_****" not found [c012] error message.
Are 2016 BMWs 'locked out' of coding changes?
Do I need to install PSdZData v.56.4?
All help/tips appreciated.
~Alan
#1,825 ·
~Alan
yes ... 56.5 would be recommended, depending on build date ... but it appears that the ISTEP level of the car is higher than your psdzdata will support
#1,829 ·
Hi Shawn,
Can I bother you again for the latest PSdZ data files , just had the herd expanded with a F56 that needs some twerking.
much appreciated !
PM sent.
Save
Status
You have insufficient privileges to reply here.
