Content moved to separate threads
Fxx, Ixx, & Gxx Series Coding:
Yes. Your PSdZData is not installed properly.I just got by 2014 335 this week and attempted to code it. I was able to check the connection using ZGW-Search and I could see my VIN and other details. When open E-sys 3.23.4 and Hit connect I get the pop up, but it does not have anything in the target area and the connect is greyed out. Any thoughts on what I am missing?
Dave
I am running Windows 8.1 with the latest updates and have no issue.I have a strange problem with E-Sys itself right now.
Running 3.23.4, it just won't open properly on my Laptop anymore. Would show you that "Warning" and the loading splash but it just doesn't "show". It clearly shows E-Sys running on the start bar and in the task manager (under Java).
Running Windows 8.1, probably with some latest update or something that might be affecting it. Also could be Java affecting it. Reinstalling E-Sys doesn't resolve the issue.
This looks great thanks! I am getting ready to code my 2014 535d but I have a Mac. Has anyone ever successfully coded on a Mac running Windows on Boot Camp?Thanks to all of the information in this thread and the exceptionally helpful people in this forum, I've been able to successfully code a couple of F10's. I thought I'd post the step by step I put together from various threads as a small contribution for beginners.
Most of this is outright theft from the various documents and notes in threads, but I wanted a consolidated document for myself. It's essentially a walkthrough of a coding session covering preparation, connection testing, pre-coding backup, editing, saving, post-coding backup, and wrap-up.
I've included a one liner indicating the basic function of each section as well as various tips found in this thread in each section. Hopefully this will be of use to some of you who are new to coding, and/or as a step by step for those who don't code frequently. Let me know if you have any suggestions for enhancing this document.
E-Sys is made by ESG Elektroniksystem- und Logistik-GmbH in FĂĽrstenfeldbruck German, just outside Munich, exclusively for BMW AG, and is for BMW AG factory floor technicians only.I've been searching everywhere but can't find any info on this "E-Sys" software. Who makes it and what is a Patch and a Token that I need to use this software?
This error means your Token solution is either no good, or it is not installed or configured properly.I am getting "failed to signFDL" c158 error while saving changes. why i ve taken error ?
I just choose my .est file for Setting- EST .This error means your Token solution is either no good, or it is not installed or configured properly.
Actually I'm not sure about token. I have just .est file. Do I miss something like .jar? Because I haven't understood token function which is need really help? I read guides, watched short clips bu nothing...And what about the patch? Did you apply the two patched .jar files?
I don't know what E-Sys version you have, nor what token solution you have, but if you have >=E-Sys 3.22.5, then you need a patch to go with the .EST Token.Actually I'm not sure about token. I have just .est file. Do I miss something like .jar? Because I haven't understood token function which is need really help? I read guides, watched short clips bu nothing...
Does TOKEN work process depend version of pzsd. and e-sys version? :dunno:
3.24.3 is mine. Are we really sure problem is coming from token? How can I solve this block?I don't know what E-Sys version you have, nor what token solution you have, but if you have >=E-Sys 3.22.5, then you need a patch to go with the .EST Token.
