Status
Not open for further replies.
Former Coding thread - Closed
779K views 3.3K replies 702 participants last post by  Almaretto
#1 · (Edited by Moderator)
#2,487 ·
ActiveHybrid3 i-step F20-16-03-504 updated by BMW dealer.
I tried to activate Daylight function.
Successfully it can be turned on but can not be adjusted brightness.
At "FEM_BODY > MAPPING_TAGFAHRL_PWM_LEVEL_1" section,
if I change the value from 64(100%) to 32(50%)
then "Unknown" is appeared in the drop box.
The brightness seemed 100%, no change.
Does anyone know how to set the brightness ?
Any help will be appreciated.
#2,488 ·
Does anybody know how to code the speedometer test when you start up the engine?
I don***8217;t mean the speedometer test at the menu where all the lights are going on and that stuff.
I mean the speedometer test where the indicator pointer are going all the way to the end and back to home position when you start up the engine. Like Audis do or like it is when a JB4 is installed.
I have seen this in a video of a F30. This guy is a prof. coder and he said he coded it last week. But these Germans over here won***8217;t say a word how things like this can be coded.
So maybe somebody here knows how this can be coded??
Or is there no way getting that to work and the video I saw is just a fake??
#2,493 ·
any answers to this??
I don't mean the speedometer test at the menu where all the lights are going on and that stuff.
I have seen this in a video of a F30. This guy is a prof. coder and he said he coded it last week. But these Germans over here won't say a word how things like this can be coded.
#2,497 · (Edited)
i-step has updated from F20-16-03-504 into F20-16-07-501 after error checking by ***12300;Rheingold 3.55.31***12301;.
Is this OK?
All this shows is that you updated your PSdZData version from 58.3 to 59.0. I don't understand what it is you are asking.
Save
#2,499 ·
That was supposed to be 59.0, not 49.0. I made a Typographical Error, and have since corrected it.
You have updated nothing on the car by just updating thh PSdZData you use to read and code the car. To update the car to 59.0, you would have to flash new firmware on all Control Units.
Save
#2,504 ·
Thank you for your reply, I got it.
By the way, could you send me
the download links of the latest Psdzdata?
Thanks again.
I don't understand this request. Your picture shows you already updated from 58.3 to 59.0 PSdZdata. There is nothing newer than 59.0, which was just released.
Save
#2,514 · (Edited)
Dealer resetted codes, and I can't recode.
Dear Shawn: I have a 2014 535D, which I absolutely love. I also loved the fact with your help, I had all of the codings where I wanted them, including auto high beams, etc. However, after getting her back from the dealer all of the codes were resetted back to factory
I am trying hard to recode, and I'm unable to. It is as if the codes have been set, so that I cannot recode. I am using Esys 3.26.1 build 42487 2014.
These are a couple of messages that I get:
1) Transaktions-Report: Aktion: Codierdaten lesen
JBBF [0] [D690375]
readCPS o.k.
CAFD_00000014_004_110_090 Fehler:
File for "cafd_00000014-004_110_090" not found! [C012]
2) Transaktions-Report: Aktion: Codierdaten lesen
CAFD_00001148_000_027_001 Fehler:
CPS read from ECU "ECUId:KAFAS2_0x5D" failed! [C070]
negative response error:
code: TIMEOUT P2/T2 occurred
description: P2 timeout on Service RDBI_CPS has error in result:
[Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not
available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU:
KAFAS2_5D_ETHERNET
severity: ERROR
[2130765072]
Any assistance would be greatly appreciated.
#2,515 ·
Save
#2,520 ·
Shawn, can you help me with this one. Trying to code TPMS via HU_NBT. While reading coding data, got this error, which prevents me from editing FDL. Do you know whhat this means/how to fix it? Can't thank you enough for all the coding help!
error is CAFD_00000DED_003_015_028 Fehler:
file for "cafd_00000ded-003_015_028" not found. [C012]
#2,524 ·
Question for ge coding experts.
I'm new to coding using E-Sys and decided to give it a whirl, using my wife's F25 my15 X3 Diesel (before moving to my F82 M4 ZCP).
So I figured I would start with an easy feature that I've always wanted for the X3, automatically folding mirrors. I followed the cheat sheet to a tee and coded both modules needed to "close mirrors + widows + moon roof through the key fob".
I, for whatever reason, can't seem to make it work with the key fob. It will, strangely enough, work with comfort access (which isn't the way I codes it). I see both the comfort access and key fob module edits both share "ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN" in the "FRM" Module, "3020" section.
I have checked and re-checked the cadf files and the edits I made are there and correct.
Any idea?
Thank you!
#2,526 · (Edited)
Any idea?
Thank you!
If you did not also code KMFRT_SCHLIESSEN, do you press and hold the Fob button for 15 seconds?
Save
#2,525 ·
Any idea?
Thank you!
#2,529 ·
Cheat sheets are ECU, not chassis-specific. And, the most common coding options can be done on any vehicles that have matching hardware. For controlling the windows and mirrors, you must do all the coding; you do not pick and choose different parts of multiple-step FDL's. Code both KOMFORTSCHLIESSUNG_FB and KOMFORTSCHLIESSUNG_PA to aktiv.
#2,528 ·
Yes. I tried holding the lock button on the key fob for much longer than 15 seconds.
Is it possible it needed some time before it started to work? I will check it again in the morning.
I don't know. It sounds like you did it right, so it should work.
I would read back the settings from CAS and FRM and make sure all of these are still set as follows:
CAS => KOMFORTSCHLIESSUNG_FB = aktiv
CAS => KOMFORTSCHLIESSUNG_PA = aktiv
CAS => KMFRT_SCHLIESSEN = Werte=00
FRM => ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv
Save
Status
You have insufficient privileges to reply here.
