Hi everyone. I'm wondering how easy it is to bleed the front brakes after changing the front hoses that go to the calipers? Someone has put doubt in my mind by saying I'd have to bleed the anti-skid mechanisms? It's an E91 by the way!
That's what I thought! Thanks for the reply!Why? The ABS pump is between the master cylinder and the wheels. Unless you get air into the line BEFORE the ABS pump, there is no reason to worry about it.
Just make sure you don't run out of fluid while bleeding the brake line.
Al
