1 - 5 of 5 Posts
BMWCCA HPDE Instructor
Do you have the Bentley manual? Get one if you don't already.
Anyhow, removing the bumper is easy. Only takes about 10 minutes, if that. Just remove the front retaining nuts underneath the plastic trim, then remove the screws that connect it to the fender liners/underbody, etc. It should be pretty obvious where it is getting hung up.
Fast Cars Suck!
I pull mine off all the time, (needed to get access to oil pan) even when jacked up :rofl:
yup its primarily 4 bolts unter your plastic trim, then a few fasteners to your underpanel (if you have one, mines MIA) and to your wheel wells, then bingo bango its off.
when pullting it back on ensure you get the two clips on each side of it into the proper slide, grove, or post(whatever you want to call it) they make sure the bumber is on straight :)
There are 4 plastic rivets that are accessed by pulling off the black plastic grille piece from the bumper cover in addition to the plastic rivets you can see when you pop off the black trim pieces. If you don't get these off it's not going to budge.
1 - 5 of 5 Posts
