hi,
i took out the right low beam bulb(right side high beam is also out), and it was 11 volts (which is good)
but once i plug it back in, it shows 0 volts (either both node were 0 volt or both were 11 volt)
anyone had the same issue? so frustrating debugging it the whole afternoon. any advise is much appreciated. Thanks!!!
I was using a new H1 bulb, and i tried two new ones, so i really dont think this is bulb short.
and the left side low/high beam is good, i also checked fuse, it is good.
138.2 KB
118.5 KB
