1 - 3 of 3 Posts
Hello everyone, I hope you all had a merry Christmas with your families! I’ve been battling a water leak for a few weeks and I suspect that my sunroof drains are to blame. I know that the tube travels down the a pillar behind the trim and out of the car. What path does the tubing take after the a pillar? I suspect that my leak is somewhere after the a pillar
IIRC, it exits below the frame behind the front wheel. Have you tried snaking heavy fishing line (like from a string trimmer) to see where/ if it exits? Are you thinking it***8217;s not clogged, but has a hole or something part way? Not likely in my opinion. The hoses are known to wiggle loose off the barbed fitting in the roof, then let water trickle down the A pillar. You fix it by dropping the front of the headliner, then zip tie it on securely.
1 - 3 of 3 Posts
