All, first time posting in roughly 8 years (it's good to be back). This post is more to vent if anything and to see if anyone else has had this problem / bad luck. I recently replaced the a/c compressor and drier on my 1998 M3 sedan. Previously, when the A/C was turned on (compressor clutch engaged), there was a death squeal from the compressor. I thought the compressor was about to go, so I ordered a new Denso unit from FCPEuro. I just did the job this weekend, and took it to my local shop to pull a vacuum / refill with refrigerant.
Unfortunately, the second they turned the compressor on, it's making the same exact death rattle. What are the odds I received a new faulty compressor? Any chance it could be the tensoner for the A/C pulley? The sound is only made when the compressor clutch is engaged, and it sounds like it's coming from the compressor, not where the tensioner is located.
Compounding this, when the shop when to turn on the fan speed through the climate control display, there's no airflow. So either a fuse has gone, or more likely the blower motor resister has died, or possibly the blower motor itself has failed. I'm about to dive into this separate issue. But since I have no airflow, I'm unable to determine if the noisy compressor is even blowing cold air.
Bright side though, at least my a/c system held the vacuum and is holding pressure / refrigerant.
Anyone want to share a similar experience or have any remarks on what could cause this issue? I'm leaning towards first sorting the climate control airflow issue and possibly just replacing the a/c tensioner before ordering another compressor and sending this one back to FCP. Any thoughts are appreciated.
Edit: I just now noticed the A/C belt seems to be slipping - thoughts on the tensioner being bad / incorrect tension? The belt feels tight with not much play.
