1 - 7 of 7 Posts
Discussion Starter #2
prices do not include shipping.
A/C switch, $ 10
http://www.freakyfranky.net/ebaystuff/parts1/ace3061311372052.jpg
Ashtray, front, $ 9
http://www.freakyfranky.net/ebaystuff/parts1/ashtraysmokeless1.jpg
Ashtray, rear, $ 17
http://www.freakyfranky.net/ebaystuff/parts1/ashtrayreare30.jpg
Audio, Stinger power distribution block, used for a week, 3 out of 4 fuses included, Digital Voltage read out, LED warning, Audible fuse warnings, 2 inputs, 4 outputs, had to upgrade to amps/volts unit, $ 35
http://www.freakyfranky.net/bmwstuff/audio/Picture 012.jpg
Balance switch, $ 5
http://www.freakyfranky.net/ebaystuff/parts1/balance1.jpg
Bumper side markers, pre or post bumpers, front or rear, $ 7ea
http://www.freakyfranky.net/ebaystuff/parts/markerfrontfat1.jpg
http://www.freakyfranky.net/ebaystuff/parts/markerrearfat1.jpg
http://www.freakyfranky.net/ebaystuff/parts1/markerfrontslim1.jpg
http://www.freakyfranky.net/ebaystuff/parts1/markerrearslim.jpg
Cabrio bottom rear seat, black, leather, $ 80
Cabrio / M3 front seats, black, leather, driverside it's heated,
passanger side needs restiching in upper outer bolster and loweer inner bolster., driverside will go with extra oem replacement pieces for 2 out of 3 ripped areas, may be able to find 3rd piece. $ 250
http://www.freakyfranky.net/bmwstuff/seats/IMG_2317.JPG
http://www.freakyfranky.net/bmwstuff/seats/IMG_2320.JPG
Central lock module, # 323 or 302, $ 35
http://www.freakyfranky.net/ebaystuff/parts/centralock302.jpg
http://www.freakyfranky.net/ebaystuff/parts1/centrallock323.jpg
Check panel , non SRS, $ 9
http://www.freakyfranky.net/ebaystuff/parts/checke302.jpg
Coolant gauge, VDO or MotorMeter, % 15
http://www.freakyfranky.net/ebaystuff/parts/gaugecoolant.jpg
Cruise Control system, auto or manual compatible, $ 100
http://www.freakyfranky.net/ebaystuff/parts/cruisesystem.JPG
C/C actuator $ 40
Cruise Control Switch, $ 15
http://www.freakyfranky.net/ebaystuff/parts1/cruiseswlong1.jpg
http://www.freakyfranky.net/ebaystuff/parts1/cruiseswshort.jpg
C/C Clutch pedal switch, $ 7
http://www.freakyfranky.net/ebaystuff/parts1/cruisecontrolclutchpedal.jpg
C/C green plug for gauge cluster, $ 7
C/C harness, $ 35
C/C module $ 30
http://www.freakyfranky.net/ebaystuff/parts1/cruisemodule2.jpg
Defroster switch, green or amber, $ 7
http://www.freakyfranky.net/ebaystuff/parts1/defrostere30e28.jpg
Dome light relay with timer, $ 25
http://www.freakyfranky.net/ebaystuff/parts1/domelightrelaydelay974.jpg
http://www.freakyfranky.net/ebaystuff/parts1/domelightrelaydelay975.jpg
Dome light switch, $ 7
http://www.freakyfranky.net/ebaystuff/parts1/domelightandswe30.jpg
Door handle, inner, pasanger side, $ 7
http://www.freakyfranky.net/ebaystuff/parts/doorlatchpass2.jpg
Door handle, inner, driver side, $ 7
http://www.freakyfranky.net/ebaystuff/parts/doorlatchdriver2.jpg
ECU, 318i M40, euro model, # 157, $ 75
Eibach ProKit springs, 325 type, (not iX/iC) compatible, 2 sets available, $ 150 each.
http://www.freakyfranky.net/bmwstuff/EibachProKit/Picture 013.jpg
Fan blower switch, 3 or 4 speeds, $ 7
http://www.freakyfranky.net/ebaystuff/parts1/fansw3speed.jpg
Fog light switch, $ 5
http://www.freakyfranky.net/ebaystuff/parts/foge301.jpg
Fog lights, late style, $ 40 each
Fog lights, early style, $ 35 ea
Fog lights, yellow, I used them as French style headlights, $ 50 a pair.
http://www.freakyfranky.net/bmwstuff/my87325ic.jpg
Fuel gauge, VDO or MotorMeter, $ 15
http://www.freakyfranky.net/ebaystuff/parts/gaugegasoline1.jpg
Hood release handle and cable, $ 15
Gauges and pod, VDO, no drilling require, including 2 prong presure sender for gauge cluster idiot light to work as it should. 16 Volts, Oil temp and Oil Pressure. you'll need an adaptor from BMPD to install pressure sender $ 35 and a temp sender $ 20, I can include a temp sender but it will be too small for oil drain plug hole. $ 100
http://www.freakyfranky.net/bmwstuff/gauges/IMG_1777.JPG
http://www.freakyfranky.net/bmwstuff/GaugeConsole1.JPG
http://www.freakyfranky.net/ebaystuff/parts1/vdosenders.jpg
Gauge cluster cover, upper, $ 9
http://www.freakyfranky.net/ebaystuff/parts1/gaugecoverupper.jpg
Gauge cluster cover, lower, $ 9
Gauge clusters, empty, $ 10
http://www.freakyfranky.net/ebaystuff/parts/gaugecluster.jpg
http://www.freakyfranky.net/ebaystuff/parts1/emptygaugecluster.jpg
Gauge cluster light bulb set, $ 15
http://www.freakyfranky.net/ebaystuff/parts/gaugeclusterlightbulbs.jpg
Glove box latch, inner, $ 7
http://www.freakyfranky.net/ebaystuff/parts/gloveboxlatchinner1.jpg
http://www.freakyfranky.net/ebaystuff/parts1/gloveboxlatchinner2.jpg
Glove box latch, outer, $ 7
http://www.freakyfranky.net/ebaystuff/parts/glovebo latchouter2.jpg
Hazard switch, $ 7
http://www.freakyfranky.net/ebaystuff/parts/hazarde30e2861311372895.jpg
http://www.freakyfranky.net/ebaystuff/parts1/hazarde30 e286131138339.jpg
Heater control knob set, $ 7
http://www.freakyfranky.net/ebaystuff/parts/heaterknobs2.jpg
Kickpanels, black or beige, $ 25
Knee bolster, underdash cover (non ABS) $ 45
Power mirror switch, $ 7
http://www.freakyfranky.net/ebaystuff/parts/powermirrowsw61311369331.jpg
Power window front lock switch, $ 7
Power window rear lock switch, $ 5
Power window switch, illuminated 1 = $7, 2 = $13, 3 = $19, 4 = $25, 5 = $31, 6 = $37 & 7 = $43
http://www.freakyfranky.net/ebaystuff/parts/powerwindowillumi1.jpg
OBC system with correct code plug, inner and outer harness, etc, $ 150
OBC with 3.8, 3.12 or 4.6 code plug and working light bar, $ 35
http://www.freakyfranky.net/ebaystuff/parts1/obcGroup.JPG
OBC compatible turn light switch, $ 25
http://www.freakyfranky.net/ebaystuff/parts/obcturn1.jpg
OBC ambient Temp sensor, $ 20
http://www.freakyfranky.net/ebaystuff/parts1/obctempblacktip.jpg
http://www.freakyfranky.net/ebaystuff/parts1/obctempwhitetip.jpg
OBC compatible door gong/chime, $ 7
http://www.freakyfranky.net/ebaystuff/parts1/obcgong1.jpg
OBC under dash harness, 10 (pre 89) or 7 (post 89) plugs, $ 30
http://www.freakyfranky.net/ebaystuff/parts/obcharnesse281.jpg
http://www.freakyfranky.net/ebaystuff/parts1/obcharnesse301.jpg
OBC under dash hood harness, $ 35
OBC control module, $ 20
http://www.freakyfranky.net/ebaystuff/parts/obcmodule1.jpg
OBC compatible horn and bracket $ 15
Rear head rest brackets, $ 40 a pair
(can get you any color, finish headrests for another $ 40)
Relay set, $ 20
http://www.freakyfranky.net/ebaystuff/parts/relaysetfusebox1.jpg
Seat belt, driver side, $ 20
Seat belt, pasanger side, $ 15
S.I. boards, big or samll batt type, code or non code plug type, $ 35
http://www.freakyfranky.net/ebaystuff/parts1/siboard1.jpg
Sport iS early front spoiler for big bumpers, $ 90
http://www.freakyfranky.net/bmwstuff...f/108_0813.JPG
Sunvisors, $ 20
http://www.freakyfranky.net/ebaystuff/parts1/sunvisors.jpg
Swaybars from a cabrio, front and rear, about as big as Eibach and other tuners.
think I have a set of urethane bushings for them, will have to look for them. $ 125 a set,
Tach, VDO or MotorMeter, 7k, $ 25
http://www.freakyfranky.net/ebaystuff/parts/tach7000.jpeg
Tail lights, Late style, L or Right side with back covers, $ 35 ea.
Turn light relay, $ 9
http://www.freakyfranky.net/ebaystuff/parts1/turnrelay613113670012.jpg
Turn light switch, $ 15
http://www.freakyfranky.net/ebaystuff/parts1/tur e301.jpg
Wiper relay, $ 9
http://www.freakyfranky.net/ebaystuff/parts1/wiperrelay1.jpg
Wiper Switch, $ 15
http://www.freakyfranky.net/ebaystuff/parts/wipersw1.jpg
http://www.freakyfranky.net/ebaystuff/parts/wipersw3.jpg
and a whole bunch of other parts that forgot to include.
also some mountain bike and road parts, including brand new forks, nite rider lights, Bolle sunglasses, smiths lenses, thomson seat post, etc...
Cruise Control Kit
Hi fporro,
Is the cruise control system still available? I didn't see it on the ebay site but I'm hoping it's still is.
"Cruise Control system, auto or manual compatible, $ 100
http://www.freakyfranky.net/ebaystuf...uisesystem.JPG"
Does the above have everything I would need to get it working on my 1990 e30 325i which has never had cruise control?
And lastly can you deliver to Sydney Australia?
Rob
Discussion Starter #4
g'day Rob,
sorry for late reply, went away for a few days. :angel:
yeap, c/c is available, shipping $ 45.
everything included, plug and play.
regards,
Frank
fporro said:
g'day Rob
Excellent. I'm also interested in the A/C switch, mine takes about 10 presses before it stays on and and the light doesn't always come on anymore!
Can you email me at [email protected]don't include thiskuitam.com to sort out payment options and delivery?
Thanks heaps
Rob
1 - 7 of 7 Posts
