1 - 5 of 5 Posts
Discussion Starter · #3 ·
FS: Z4 Winter Wheels - Will they fit on E92?
best to hear it directly from the source, so I emailed TireRack where I bought these. It is a function of lug pattern and wheel offset. I will reply to the post when I get TireRack's response.
FYI, the detailed specs on tires and wheels follow:
17x8 Mille Miglia Spider II Bright Sil
225/45HR-17 Dunlop Winter Sport M3 RunFlat
And again, the tires / wheels have only about 2K miles on them.
Will post TireRack replywhen I receive
thanks
Discussion Starter · #4 ·
FS: these particular winter tires / wheels WILL work on E90-93
So I went back and forth with TireRack today. It turns out that these wheels will work with E90-E93 NON SPORT PACKAGE based on the following:
1 - lug pattern is correct (5-120)
2- offset of these wheels is 40mm
3 - Tirerack is selling other 17x8 wheels with 40mm offset mated to 245/45s for E90-93
It is safe to say that if your E90-93 came with 17s, then these wheels will bolt directly on with no clearance or geometry issues.
1 - 5 of 5 Posts
