1 - 4 of 4 Posts
Does anyone know how to convert ".xml" or ".der" files to ".fsc"?
My night vision camera has "04" and "05" activation files in ".xml" and ".der" format, but E-SYS can only import files in ".fsc" format;
The document is attached, For your research. please change the format to .rar;
If you have both '.fsc' and '.xml' and '.der' files (files of the same module), can you send a copy to my mail to see how they relate to each other?
[email protected]
Thanks and best regards
A small program exists to convert a .fsc and a .der to a .xml, but not the other way around. Signing an FSC with the .der security certificate to form the .xml seems much simpler than attempting to disassemble an xml using only the security certificate. I've attached a pack of FSC files with security certificate and XML for you to check out.
My suggestion would be to import the .xml files using ISTA.
Discussion Starter #3
I'm back:)
Because I only have FEM / BDC, ACSM module and night vision module. ISTA reports an error after diagnosis. It is unable to import the XML file into the night vision module. Is there any way to solve this problem?
Discussion Starter #4
What's the way for ISTA to skip the programming steps of other modules and directly execute the steps of importing XML file into night vision module
1 - 4 of 4 Posts
