Figured id make a short simple post to help others.
My ac and heat werent blowing air. All buttons lit and were working but as I adjusted fan speed, defrost, feet, etc nothing happened. Picked up an FSU for about 50 bucks and it worked.
First remove three screws holding dash piece on under steering wheel. (third one is above gas pedal) and remove piece and wiring to foot light
Then remove the torx 15 (1) screw and phillips (1) holding in the fsu which is tucked way in and above and to the right of the gas.
Replace the fsu and my air/heat began to blow air perfectly
