Bimmer succumbed last week in what turned out to be one very dead fuel pump. Today, a week after replacement, it got cranky in the morning and did a number by refusing to start. It would crank fine, catch and turn for a second or two then die, finally managing to start after half a dozen tries. Two separate times it repeated the act.
Given that I absolutely cannot be car-less this particular weekend, took it to the nearest mechanic capable of doing something about it, aka The Dealer (couple of blocks from home, could have pushed it in a pinch...). Making Murphy proud, the car refused to fail in their presence. Then, miracle of miracles, dealer refused to take it in, saying that since there were no codes, no warning lights and no failures, result would be depriving me of the car with no warranty of ever finding a failure. "Maybe a speck of dirt got stuck somewhere and caused the fail, probably passed thru and is history" is literally what they said.
So, after this long rant, the focus of the thread: what additive have you ever added to a Bimmer's gas tank to clean out the injectors, remove contaminants and make it better? Did it work?
P.S. Fast Bob's idea of a stuck check valve in the fuel rail becomes ever more attractive, although the original pump was quite dead. Tried to energize it after draining the fuel and it will not go.
