1 - 8 of 8 Posts
2008 535xi car loses fuel when going between 65-75 just randomly on the highway. You press gas and nothing happen, then it starts driving fine again.
We thought it was coil pack as there is misfire on 1 and 4. mechanic replaced both coil pack and the issue still exist.
Now they want to replace all 6 fuel injectors. parts alone is $1600.
Question are there any other known solutions
and can you use remanufactured injectors
thank you
Nac
If your build date of your car is as cited below, see if the injectors have already been replaced under the recall.
Voluntary Emissions Recall Campaign 10E-A02: N54 Inspection and Replacement of Injectors
MODEL
E60, E61, E71, E82, E88, E90, E92, and E93 with the N54 engine produced from 04/02/2007 through 10/31/2008
Discussion Starter #4
I called the dealer and they said there is no recall. built is 02/08 I am going to call again tomorrow and mention that above
Nac
Here is some more detail.
SI B13 14 10 Fuel Systems
December 2010 Technical Service
PERFORM THE PROCEDURE OUTLINED IN THIS SERVICE INFORMATION ON ALL AFFECTED VEHICLES THE NEXT TIME THEY ARE IN THE SHOP FOR MAINTENANCE OR REPAIRS.
SUBJECT
MODEL
SITUATION
The piezo injectors may cause misfire faults with erratic engine operation.
AFFECTED VEHICLES
This Emissions Recall involves E60, E61, E71, E82, E88, E90, E92, and E93 vehicles with N54 engines which were produced from 04/02/2007 through 10/31/2008.
In order to determine whether a specific vehicle has had this Emissions Recall Campaign completed or is affected by this Recall Campaign, first check whether the Recall Completion Label, SD 92-406, is attached to the right (passenger) rear side of the hood in the engine compartment, close to the windshield. If the label is found, the Campaign has already been performed. If the Recall Completion Label is not present, it will be necessary to utilize the "Service Menu" of DCSnet (Dealer Communication System) or the Key Reader. Based on the response of the system, either proceed with the corrective action or take no further action.
Copy of the customer letter is attached.
CORRECTION
Check the injectors’ production date/serial numbers (using the DMC scanner) and replace if required.
AKA"Califorinadaddy"
SUBJECT
MODEL
SITUATION
AFFECTED VEHICLES
CORRECTION
Check the injectors' production date/serial numbers (using the DMC scanner) and replace if required.
Is there a mileage limit for this recall? I have like 130K on my 07-2008 535I
1 - 8 of 8 Posts
