1 - 7 of 7 Posts
Anyone had a problem with their fuel pump? Mine went out only after 5000 miles. First thing I noticed was no whirring sound coming from the fuel pump when I turned the ignition key. Luckily, after a minor battle, dealer was able to look at it the same day. They found a blown fuse and a burnt out fuel pump. Just wondering if there is a common problem.:dunno:
Here since day one
I know there was a TSB on my 2001 330Ci and they replaced mine but I don't know if it affected 2002's
BTW the newer one is REALLY loud at idle . . .
Alan,
do you know the TSB numbers ?
also what build month is your'01?
PS: sometime on idle from my driver side gas tank there is "brllprrl" noise (like blowing air true straw in cup with water) , guessing it's coming from the pump, anyway is that the problem if they are going bad ?
THX in advance
3c
My 06/2000 330Ci had a recall per the BMW Service DCS. SIB # 12 13 00, Replace Leak Dianostic Pump. P/N 16 13 6 756 440.
This only applied to certain 2001 Models.
I know at my dealership.. my service guy told me that the s54 M3/roadsters some had ripped thier fuel pumps due to redlining the car before the break in was done... i assume it busted not by doing that just once
1 - 7 of 7 Posts
