1 - 4 of 4 Posts
Hi all, sorry if this has been asked/answered or if im in the wrong place but i took my car in for a state inspection the other day and it failed with "fuel system not ready" under the OBD system - readiness status. I've read this has something to do with having to complete a drive cycle. Not sure why im getting this error but may be due to not driving the car enough. In the past i've used E-Sys to do some coding. Its been awhile and need to re-familiarize myself with the s/w but is there any way for me to check the fuel system ready/not ready status with E-Sys? If so can someone point me in the right direction please? If not, what would i need to check this??
650ix coupe 2013
OBDII Enet cable
E-Sys (need to check version but probably out of date)
Thanks in advance.
Discussion Starter #3
Thanks for the quick response. Would you know if there's any way to "make" the fuel system "ready from not ready" with ISTA+ or INPA?
You should check the errors with ISTA and after that select calculate test plan. But I can’t help you much without knowing more about that error code
1 - 4 of 4 Posts
