Well, the fuel tank lock ring came off easy enough so I could inspect my fuel pump. Now the darn lock ring is just not engaging with the treads on the tank neck. I can see where the marks are on the lock ring so I cam return it to the original position. My problem is the lock ring pops off as I rotate it. So frustrated for something that should be straight forward. I tried screwing it on without the fuel pump and sending unit. Lock ring goes on with no problem. So the sending unit must be sitting high enough to give me grief. I've been making sure the collapsable leg with the spring is seated in the tank, but how hard are you suppose to push down on the cover? I'm expecting for something to snap mintue. No DYI write ups I've come across mentions this grief. Any tips would be greatly appreciated!
