OK, R level sensor went out and took the dash fuel display with it. Symptoms were: dash fuel level not responding to fill up until car restarted several times, then transitioned to zero fuel being displayed on the cluster a couple of days later.
Opened the cluster and saw: L fuel level reporting normally, R fuel level zero. Replaced the fuel pump and R fuel level sensor. (Fuel pump because it seemed to quit one day going in to work but ran normally on the way home.)
Now: Dash fuel gauge not reporting correct amounts. Sometimes the needle will start out at 1/4 and 30 miles later be up to 1/2. Just filled up because fuel level was showing almost empty, range 31miles, and it only took 9.5USG to fill it up. Now when full, (fuel at top of the filler neck) fuel needle is pointing to just over 1/4 but cluster is reporting 34.0L/25.8R = 59.8Liters = bout 16USG.
I don't know where to start. Fuel gauge seemed to be accurate until the R level sensor went out, now it's gone crazy and does not seem to reflect the level displayed by test #6 in the cluster.
ANY help appreciated!!
Thanks much,
Jim
Thanks much,
Jim
