Poking fun at the pictograms, apparently my car has the following equipment:
A "Bong" (below the steering wheel, top left)
A square box that takes TWENTY fuses to run (directly below the "bong")
The possibility of having a convertible?? WTF? (Third column, 5th down)
The possibility of having a height adjustable suspension? (Third column, 4th down)
A very basic disconnect switch (third column, 11th down). Oh wait, might that be the sunroof?
Some kind of satellite (first column, 11th down)
A thermometer that takes 4 fuses to run, (first column, 13th down).
A snow making machine that takes 6 fuses to run (second column, second from bottom)
Something that is slipper when wet (second column, bottom)
A battery - (third column, second from bottom).
