1 - 20 of 36 Posts
Vendor
Car Vehicle Hood Motor vehicle Automotive tire
The BMW E30 has long since been named God's Chariot. We at Garagistic think that is an apt name; suiting not only in name but in spirit. We are proud to offer e30 performance parts as well as e30 oem parts. We are honored to carry performance parts for E30's but also OEM goods as well. No matter what type of application you might be using your BMW E30 for, we have something for it; anywhere from tracking your E30 to dailying it, we've got you covered. The performance parts we carry include e30 strut bars, e30 cross brace, e30 odometer gears, and sway bar links to name a few. This list will continue to grow, so stay posted! Whether the primary application of your e30, from spec e30 , building a street monster or a drift beast, we will have the e30 parts here to keep your bmw on the road or track and outperform the competition!
Automotive tire Automotive lighting Automotive design Motor vehicle Bumper
Are you looking for the ultimate in precision shifting and feel? Want to eliminate all slop in the shifter for that tactile mechanical feel and satisfying shift? Look no further than the Garagistic Solid Chassis Mounted Short Shifter! Comes into finishes Bare and Black Anodized.
Bicycle part Gas Nickel Rim Auto part
Gas Glass Vehicle door Monochrome photography Transparent material
Current Lead time: Shifter will ship ~5-7 Business Days after the order is placed.
FEATURES AND SPECS
  • Solid Billet aluminum construction
  • precision spherical bearing pivot point
  • No permanent modifications are required for installation!
  • Multiple shift stalk heights available (like OEM, Medium, Tall)
  • Multiple Shift knobs available (Delrin, Aluminum, Soft, Standard, Vintage, Tall)
  • Available with OEM style slot rod for compatibility with BMW OEM shift knobs (select OEM height option)
  • Shift knobs available with recess for BMW shift pattern emblem
  • Anodized aluminum 5 speed shift emblem included with recessed shift knobs (4 speed, 6 speed, and G logo emblems sold separately)
INCLUDED HARDWARE
  • 6 Flat Socket Bolts (top plate retaining bolts)
  • 7 Thumb Alen Bolts (Bottom plate retainer bolts)
  • 4 Small Set Screws (2 screws for shifter rod, 2 screws for lower rod)
FITMENT: WILL THIS SHIFTER FIT MY CAR?
  • Not compatible with iX AWD E30
  • Short option not recommended for E36 and up chassis
  • Will fit on round transmission tunnel holes between 3 1/4" - 3 3/8" diameter
  • Fits most BMW chassis such as E30, E36, E46, Z3, E39, E34, and many more (some very early model cars will require some modification to the opening in order to properly install the shifter. Please check the opening size based on the dimensions provided above.)
  • 1984 - 1985 E30 Models have a smaller diameter hole in the trans tunnel for the shifter. This will require you to remove enough material to increase the diameter of the hole in the trans tunnel with a Dremel for proper installation.
  • Please Note: Some OEM BMW shifter rods have a very slight tilt, therefore some shifters will also have a slight tilt once installed.
FITMENT: WHICH SIZE ROD SHOULD I GET FOR MY CAR?
  • In general the longer the rod the longer the shift-throw will be and the less notchy it will feel while the shorter rod produces a shorter shift-throw and a more notchy feel.
  • It is important to note that due to the varying heights of center consoles in different chassis, certain size rods may be too small/large for you. For example, the E30 center console is shorter than the E36 center console so a short height shifter rod will be too short in an E36.
We introduced the Solid Chassis Mounted Shifter to the community to provide an affordable race shifter that is simple to install and completely reversible. However, due to the solid mounted design, stiffer polyurethane and solid engine and transmission bushings are required to run those chassis shifters. While the solid shifter is great for the track there is a compromise of added noise and vibration in the car. For this reason, we came up with a short shifter option that does not sacrifice the comfort of OEM rubber bushings: the Garagistic OEM Supreme Short Shifter.
Motor vehicle Automotive tire Asphalt Automotive exterior Bumper
This new Supreme Short Shifter with the same basic concepts in mind: easy to install and completely modular – meaning you can easily switch between different shifter rod heights and different shift knob types (something other short shifters do not have) and even allows the use of different length shifters and shift knobs from our solid mount family. Not to mention you can adjust the throw to your liking. The "longest" setting simulates what the common OEM+ upgrade z3 shifter would feel like. Move it lower and the throw becomes shorter and shorter as you move lower pivot down. Our Supreme Short Shifter does not eliminate the OEM shifter carrier unlike our Solid Shifter, so you can use this shifter with an OEM rubber engine and transmission bushings! We are constantly making improvements on our parts and the shifter now has a fully threaded center rod and ball for maximum adjustability and compatibility. This is the ultimate short shifter for your street-driven BMW or absolute track animal.
Hood Automotive lighting Automotive tire Bumper Flash photography
Hood Automotive tire Automotive lighting Automotive design Trunk
FEATURES AND SPECS
  • No permanent modifications required for install!
  • Available with OEM style slot rod for compatibility with BMW OEM shift knobs (for OEM height option only)
  • Fits Most BMW chassis such as E30, E36, E46, Z3, E39, E34, and many more. (DOES NOT FIT E46 iX or E30 iX AWD models. PLEASE CHECK NOTE BELOW)
  • Will not work with E30 driveshaft vibration damper, it will need to be removed
  • 2001-2006 BMW M3 Manual Shifter Lever PN: 25112228069 fitment WILL have some tilt
Solid Shifter vs. Supreme Shifter, Which one to choose?
Black Font Bumper Automotive exterior Gas
To start off, what is a DSSR you ask? Well, it stands for dual shear selector rod, it's a selector rod that will spread the torsional force on both sides of the selector rod instead of the OEM piece which connects from one side only. Based on the concept of the E30 M3 DTM cars of legend! Going to a DSSR in your E30 will mean less play in the shifter, (decreases side to side motion). This means a more precise and smooth shift every time.
1 - 20 of 36 Posts
