are you talking about a click all the way at the bottom of the pedal travel? if so, that is normal.dkl said:Does anyone have a problem with their gas pedal making a clicking/clacking sound whenever it is pressed or depressed? Just wondering if there's a simple fix other than having the dealer swap it out. Thanks.
No...it's just at tip-in, on both directions. I know about the "kickdown" click all the way at the bottom, but that isn't it. Mine is happening at light throttle, just as what Sonet is describing. From Sonet's post, it sounds like a common problem on the E46, so I'm wodering if anyone else have noticed it on the E53 as well. So far, it doesn't sound like replacing the pedal will help, so I'm looking for an "innovative" fix.vinu_neuro said:are you talking about a click all the way at the bottom of the pedal travel? if so, that is normal.
what actually the purpose of the click all the way at the bottom?Moderato said:My gas pedal did this for a couple of months and then it stoped. :dunno:
The purpose of the click all the way down at the bottom of the throttle is due to the "kickdown" function, which tells the auto tranny that you want to downshift NOW when in full auto mode (D).vinu_neuro said:what actually the purpose of the click all the way at the bottom?
I don't think we're talking about that, it's a click that would occur just when the pedal is first pressed, plus my car is an MT anyway. I think since my car was new something was sticking and after a few months it just went away. :dunno:dkl said:The purpose of the click all the way down at the bottom of the throttle is due to the "kickdown" function, which tells the auto tranny that you want to downshift NOW when in full auto mode (D).
Moderato, I think you've misunderstood my previous post to vinu_neuro. You and I are talking about the same click that happens at the begining of throttle tip-in, which I still have and would like to find a solution. Vinu_neuro was asking for an explaination of the click at the bottom of the gas pedal, and I provided one for him.Moderato said:I don't think we're talking about that, it's a click that would occur just when the pedal is first pressed, plus my car is an MT anyway. I think since my car was new something was sticking and after a few months it just went away. :dunno:
Anyway, i was having a similar sticking/squeeking problem. they ended replacing the whole gas peddle assembly. i think it was a service bulletin.Moderato said:I don't think we're talking about that, it's a click that would occur just when the pedal is first pressed, plus my car is an MT anyway. I think since my car was new something was sticking and after a few months it just went away. :dunno:
