1 - 4 of 4 Posts
some help required 330d e90 changed my auto gearbox oil and new gasket fitted now its leaking but not from the gasket from up above any one shed some light on this
Where up above? You need to follow the leak up to its origin. If it's transmission fluid and not from the pan gasket, most obvious sources are fill plug and Valvetronics sleeve.
What kind of gearbox shift box to you own and how many gearbox foward changes does it feature. All i know is ATF fluid dextron is one of the most commercial lubrication atf oil look at your filler plug.:dunno:
1 - 4 of 4 Posts
