1 - 3 of 3 Posts
Bmw e39 98 523i manual. While driving I have about 14.2-14.4V but when I stop I often get about 12.4-12.6V and sometimes head unit dies. Is this a generator problem? Thx
Alternator voltage increases with rpm, so its normal.
Maybe you should check your headunits wiring?
My voltage reading never drops under 13.6V while running, as measured from the lighter outlet with no load. This voltage is only that low for less than a minute after start-up, and typically reads 13.9-14.1V.
A regulator with a different set-point might be slightly different, but under 13V indicates that the alternator is not working.
The usual advice: remove the alternator and measure the brush length. New spec is around 13mm, replace under 5mm. Wear is usually slow and linear unless grit enters the well-sealed brush chamber.
If the brushes are short, and the alternator isn't heavily corroded, I recommend replacing only the voltage regulator. Rebuilt alternators have a significant risk of being bad. There are probably only a handful of bad alternators in the system, but they each go out to a new customer every day and are returned the next.
1 - 3 of 3 Posts
