1 - 1 of 1 Posts
Dinan Camber Plates Kit for BMW F2x M235i 228i F3x 320i 328i 335i 428i 435i + FREE Ground Shipping!!!
Product Description:
Dinan's F2x / F3x Camber Plates allow an impressive 43mm of total camber adjustment (30 negative, 13 positive) providing for a more aggressive negative camber setting that dramatically improves grip in the turns for reduced understeer and razor sharp turn-in. The positive adjustment range on the camber plates is unique to Dinan® and allows the end user, if desired, to retain OEM camber settings on a lowered car or to combat excessive negative camber brought upon by springs that aggressively lower the car. Not only do the Dinan camber plates provide a wide range of adjustment but they also have ride quality in mind like all of Dinan's suspension components and are designed to properly retain the bumpstop so that it compresses as designed from the factory. There is no reason for camber plates to wildly inhibit ride quality if engineered properly. Dinan camber plates are also built to take a beating and are the only ones that utilize a steel alloy mount plate that will resist deforming from pot holes on the street or curb hopping at the track.
Aggressive drivers will benefit from reduced outside edge tire wear as well.
Benefits of the F2x / F3x Camber Plate Kit:
  • 43mm of total camber adjustment (30 negative, 13 positive from OEM)
  • Decreased understeer
  • Decreases outside edge tire wear
  • Steel alloy mount plate and not aluminum
  • Fits with factory strut tower weather seal
Special Note: Warranty applies to all parts except for the spherical bearings.
PM or Email for discounted pricing + FREE Ground Shipping on all Dinan Parts!!!
1 - 1 of 1 Posts
