1 - 1 of 1 Posts
getBMWparts.com | F22/23 2 Series Dinan 19in BBS CI-R Wheel Sets! Black or Silver + FREE Shipping!!!
Product Description:
Dinan has used its extensive knowledge of BMW wheel fitment to use the BBS CI-R product line to its fullest.
BBS Wheel Set Highlights:
+ One Piece Counter Pressure Cast Wheel
+ Back-milled spoke area
+ Spun inner rim using BBS Flow Forming Process
+ Featuring stainless steel rim protector
+ Weight optimized by FEM analysis
+ Compatible with BMW tire pressure monitors (RDC)
+ Includes DINAN center caps and BBS centering rings
Color:
Platinum Silver or Satin Black
Specifications:
Front Wheel
Size: 19" x 8.0" et45
Weight: 27.2 lbs
Recommended Tire: Michelin Pilot Super Sport or P-Zero Corsa ***8211; 235/35-19
(For other tires see note below)
Rear Wheel
Size: 19" x 9.0" et48
Weight: 24.9 lbs
Recommended Tire: Michelin Pilot Super Sport or P-Zero Corsa ***8211; 265/30-19
NOTE ***8211; If using a tire other than the recommended tire: The physical dimensions of different tire manufacturer's products may vary for a given tire size. In some cases minor trimming of the fender well lip may be required due to vehicle production tolerance variations.
Shop Dinan 2 Series Parts Here - PM for Special Forum Pricing!!!
1 - 1 of 1 Posts
