getBMWparts.com | PRICE DROP: Yellow M Performance Big Brake Kit!!!
Was: $1840.00, NOW: $1250.00 (for a limited time)
Brembo high-performance 4-piston aluminum fixed caliper on the front axle and 2-piston aluminum fixed caliper on the rear axle. Yellow calipers with an M logo on the outside of the caliper. Improved thermal resistance thanks to larger, internally-vented lightweight construction sports brake discs. Cross-drilled and grooved brake discs also reduce water film build-up between the brake lining and the disc surface. Drilled and grooved, internally-vented lightweight brake discs with riveted aluminum hat. *Rear rotors sold separately.
Fits F2x 2 Series and F3x 3 and 4 Series!!!
Shop Genuine BMW M Performance Parts Here!!! :thumbup:
