Hi, I tested my circuit. First started by checking the resistance, once more, of the actuator. This morning, it was at 2.5 ohms!!! How is this possible???
Anyway, I unplugged the connector at the module, plugged the actuator back and took my reading: 2.7 ohms
So the wires are good. While I was there, I did 1 wire at a time, and both gave me .2 or .3 ohms. I hooked everything back up and started the engine right away, expecting to see the ASC light on, but it wasn't. Took her for a spin, and there it was again. So I thought: that's it. I installed a 8.5 ohms 1w resistor that I bought earlier this morning. Installed the resistor instead of the actuator, went for a drive and the light came back again. Back in the driveway, I installed a 1,5 ohms resistor instead. Same result. I installed the two resistors together for a 9.7 ohms (10.4 mesured) and went again for another drive. Light on again. I stopped by the side of the road and disconnected the ASC sensor at the auxiliary TB. Now, both ABS and ASC light were on. Plugged the sensor back and went home.
Any other ideas are welcome. I'm not a quitter. I never quit. But I guess that for this time, I think I'm done, being out of ideas. And I have been at it way before this post. Can't waste any more time trying to fix something while the weather is perfect and the car is fully functionnal, rergardless of that stupid light.
