1 - 20 of 26 Posts
I'm going crazy! I've bought a 2000, 328i and it has very strange problem.:mad:
The car doesn't accelerate and the engine is very sluggish, particularly when you push the gas pedal! The EML light is on and there is yellow triangle sign coming on on the dash, plus the check engine light. Now I've taken it to about 10 BMW mechanics and they can't figure out the problem. I have change the air flow meter, throttle body, spark plugs and changed the oil couple of times! non of them helped!! (p.s. could be the oil pump?)
These are the errors that BMW dealer gave me:
1-camshaft position sensor circuit malfunction (#65)
2-signal, 02 sensor, bank 1&2, before catalyst, below min. value.(#151/154)
3-signal, throttle pedal travel sensor(#172 & 111)
4-engine throttle out-put-stage shut off(#169)
5-pedal travel, brakeslamp switch
6-air mass meter signal faulty(#08)
7-pedal travel sensor(#117)
8-electical power in excess of 18v(#120)
9-CAN connection to DME(#148)
10-Streering angle sensor(#182)
**** I repeat, I have changed throttle body and air flow meter already ****
Please help me out, I have no Idea what's wron with this car!
(BMW 328I, 2000, 125,000 miles)
You have so many error codes that I suspect the DME (the elctrical brain) is the problem, because it is improbable that many sensors and componets would all fail at about the same time.
You would have 18 volts somewhere? I don't get that code at all.
But diid the dealer tell you that the DME was ok, or not?
Alternatively is the DME completely plugged in? I would start with the theory that the DME is not correctly plugged in, and inspect that. If it is plugged in and the wires are sound, then a new DME is really expensive.
I assume the car was slow when you bought it, and it had an expensive problem, and that is why it was sold. Or what?
Keeping it surreal
I would suspect the cam position sensor as the culprit....
Regards,
Bob
Banned
KAYVAN said:
I'm going crazy!
Replace the camshaft position sensor. You have to find out if it's the exhaust or intake side.
Replace both the pre cat o2 sensors on banks 1 and 2
Replace the gas pedal. The sensors inside it are faulty
Replace the brake light switch. That is a big input to certain systems.
If you replace the throttle body and you're still having the EML problem after replacing the parts that I just mentioned, then you may need to replace the entire engine wiring harness.
Also, did you buy a used MDK (throttle body) or someone got it for you?
Jon,
The throttle position potentiometers are located in the MDK (throttle body), not in the accelerator pedal on that car. The M52TU motors had a cable actuated electric throttle, not completly drive by wire like the M54 cars. So, the pedal assembly is not the problem.
Kayvan,
You do have a lot of fault entries, so it is kind of hard to see what is going on. You should have the fault codes cleared, and see which ones return. Some of the faults could have been caused by someone unplugging electrical connections with the key on.
A faulty cam sensor is very common, and will cause poor performance. It will set a check engine light, but should not cause the EML light to come on. You may have a cam sensor problem, but I don't think it is the root of the problem.
You have a few throttle related faults. Who replaced the throttle, and did they know what they were doing? You are supposed to clear the engine throttle adaptations when a new throttle is installed. If not, the engine will probably run in fail-safe mode (which is what your car is doing from what you are saying).
The 18+ volts fault is also alarming. It is possible that your alternator has a problem, and is supplying too much voltage to the control modules. The engine and transmission control modules are very sensitive to voltage supply. Too much or too little will cause them to freak out.
Good luck, and let me know if I can help at all.
Andy
Banned
streetk14 said:
Jon,
Yes you're correct. Had to check my tech manual for that one.
Anyways, there's a bulletin on this matter for the EML. Basically a bad MDK can cause a thottle pedal travel sensor fault which I thought was a bad pedal position sensor. SIB 12 07 99.
The member got back to me and he said he replaced the MDK with a used unit. I told him to buy a new one and to have a shop clear adaptations.
I would not have much faith in a used MDK. I think what you suggested is a good start, and hopefully will solve the problem.
Andy
Protect your (lug) nuts
I've got a 328i and ive had my fair share of issues! I feel for you, i think the 328i's are pieces of sh1t.. which is why im getting a 330i next month.
Hope you get it worked out. I know how frustating these cars can be. So frustating, I've almost considered another automaker, but just couldnt quite go through with it (IE: Acura).
Strange, I've had almost zero problems with my E46 328i. Mine has only 47k on the clock, but no real issues to speak of. Actually, I lied. It blew out a brake light bulb today ... ;)
Andy
Andy
Well its good to know that not all of them are crap! BTW, you've probably got the lowest miles for a 328i that ive ever heard of! :thumbup:
Discussion Starter · #11 ·
Thanx you all for these helps and suggentions. I think i've solved quite a few of my problems. The best news is the EML light and that yellow triangle sign doesn't come up any more. However the check engine light is still on. NOW...before i change those parts i used to get 9 error codes, but now i only get one which is PO340...Camshaft postion sensor circuit malf. In addition, I was suspecting that too much sludge could also cause the engine to be sluggish too.
Anyway, I opened the valve cover and took a look at the inside of engine...I can say YES there was alot of sludge in there. I was able to somehow clean the parts on the top, but i guess i need to flush 3-4 more times to get rid of this sludge. However even after I cleaned some of the sludge the power of the engine didn't improve that much so I'm leaning of changing that Camshaft position sensor, but some body told me that error is cause by the sludge and it wil go away after i clean it....I don't know what to do now! flush more or just change the camshaft!!
My 323I has been very good to me so far got it with 72K now at 93K no issues... Oh I changed my head gasket today and got and oil change... no sludge in there thank you very much...
I hope you did not pay more than 7K for that car but yes you need to desludge it.
Considering they havent made a post since August 2006, I doubt its still an issue..
42K on my 323Ci... how about that? OK, it's no 328i... and low mileage is nothing to be proud of to a 7-yr old car. :(
KAYVAN
I have the eml problem same as yours.Cant figure out what is the problem!Could you tell me what you have done to solve this problem!!!So fu..in tired of this problem...Plz!!!
Keeping it surreal
KAYVAN
Dude....this thread is from THREE YEARS ago !
Freedom isn't free!!
2018 Glacier Silver 340i M Sport
KAYVAN
The first thing that came to my mind when I read the OP's problem was failing cam shaft postion sensors. Easy fix.
Oh, well. At least we know he searched. ;)
I also recommend replacing your fuel filter.
1 - 20 of 26 Posts
