1 - 5 of 5 Posts
Can anyone tell me the symptoms of a guibo failing? When I'm letting off the clutch to take off, sometimes i get a little shimmy or pulse feeling.
Could be. Mine would shudder when under load. Once I hit 40 or so it would smooth out. Got worse as time went on.
Discussion Starter #3
Thanks for your reply, im gonna look at it later today. I've felt something similar in my '75 camaro, it turned out to be a broken bell housing. I'd much rather it be the guibo.
Keeping it surreal
You might still have the original CDV (Clutch Delay Valve), which will initiate a vague, imprecise feeling in the clutch system. It is easily removed (less than 30 minute job, even for someone with limited wrenching experience) , and FREE too ! :thumbup:.
It was a hot topic for quite a while, so there`s plenty of info archived right here.... just do a SEARCH for "CDV-ectomy"....
Discussion Starter #5
Thanks for the info, definitely gonna do that today, also gutting the cats and installing defoulers so it doesn't throw codes.
1 - 5 of 5 Posts
