281 - 300 of 405 Posts
On Android you get Last Mile, Twitter, Eco Pro Analyzer, RSS Feeds, and most valuable, audio over USB. That's it. No multimedia apps like Spotify or Pandora - www.bmw-carit.com is too busy showing off their 'projects' on the web sites - they can't be bothered to include some useful features or improve compatibility of the junk Connected Drive app.
How utterly terrible!!!
What about buying an iphone 4 and plugging it into the USB in the armrest, then having it connect to an Adroid phone via a WiFi hotspot?
HI,
this will work, this works too, if you use an iPod, one of the latest with WiFi.
Thorsten
Yes, that is how I had it working, with an iPod running Connected Drive App and using my Balckberry HotSpot.
Hi shawn,
I want to retrofit my 2012 F31 with SA 6NR BMW Apps.
My car is equipped with 6NF external music interface to smartphones, 6NL connection bluetooth and USB devices, 609 Navi professional (HU_NBT), 612 BMW Assist, 614 Internet preparation, 615 extended BMW online information and BMW online.
As I red I only have to add SA6NR to VO, import 9C code and recode HU_NBT. Am I right?
Do you have a trustable source for buying the FSC?
Lot of thanks
greets
Mike
Hi shawn,
Lot of thanks
greets
Mike
Yes, Import and Activate 9C FSC Code, and Code car for 6NR.
PM sent.
Hi Shawn,
I have a 2014 F10 fitted with NBT and 6AA, 6AB, 6NS, 609 and 614. I want to retrofit 6NR for internet and BMW Apps.
Just to confirm, all I have to do is VO code 6NR follow below instructions for FSC code?
Diagnostic Address (Hexadecimal) = 63 (99 Decimal)
Application Number (Decimal) = 156 (9C in Hexadecimal)
Base Variant = HU_CIC
Upgrade Index = 1
Would the only difference be Base Variant = NBT? Anything else?
Please send me contact for 9C FSE Code.
Thanks in advance!
Eugene
Hi Shawn,
Upgrade Index = 1
Thanks in advance!
Eugene
Yes, only difference is the Base Variant would be HU_NBT.
PM sent.
If you need 9C code cheap price - let me know.
I'm also can help with another FSCs.
Are you talking 9C FSC Code issued by BMW AG or your alternate one loaded via USB?
Hi shawn, I kindly ask for your assistence for activating 6NR
As I wrote my car is a 11/2012 F31 equipped with 6NF external music interface to smartphones, 6NL connection bluetooth and USB devices, 609 Navi professional (HU_NBT), 612 BMW Assist, 614 Internet preparation, 615 extended BMW online information and BMW online.
For activating 6NR I followed your instruchtions.
Bought a FSC for my VIN, edited FA and added 6NR to it, wrote it to car, upgraded the FSC to
diagnistic Address 63, application number 156, HU_NBT, uprade index 1. After this I checked FSC Status and got:
AppID 156
UpgradeIndex 1
SWTType SWTclassic full
FSCStatus accepted
FSCCertStatus accepted
So I think I have the right FSC and it is activated.
For coding I red back the new FA from car, checked if it´s the right one with 6NR included. Red SVT(VCM), right-click on ECU (HU_NBT itself) and selected CODE.
Then it started to code HU_NBT but finished it with error:
[HU_NBT - 63] "finalizeECUCoding" wurde gestartet.
[HU_NBT - 63] "finalizeECUCoding" wurde beendet.
[] Es ist ein Fehler aufgetreten, bitte ĂĽberprĂĽfen Sie die Log-Dateien!
[] - [Exception - HU_NBT - 63] Job-AusfĂĽhrung ist fehlgeschlagen: negative response error:
code: service returned global negative response
description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; ECU: HU_NBT_63_ETHERNET
severity: ERROR
After that Apps were not in the menu. So I FDL coded all items with A4A and set them to active, this wirked fine without errors.
Now Apps appeared in the Connected drive Menu, and below Apps there was the topic "Communication assistent". I started it and it told me to connect my phone, I did this and the system recognices my phone (Iphone 5 with IOS 9.3) when I put it into the snap in as well as when I connected it via cable to USB. After that the system told me to start an app on my phone, but when I start th "BMW connected" App nothing happend. Neither the car checked this App, nor the app found a connection to the car. With the APps menu "check connection" it tells me that ther is no connection to the car. Now I´m a little confused.
Why do I get an error when I VO code the HU_NBT?
Why sees my car the phone, but dose not see the started App "BMW connected"
Why does the App not find a connection to the car although the car sees the phone.
What did I wrong?
Regards
Mike
...Why do I get an error when I VO code the HU_NBT?
What did I wrong?
Regards
Mike
What is FA Build Date?
