Guide for, how to import FSC 9C code, 6NR
127K views 404 replies 111 participants last post by  shawnsheridan
#1 ·
I'm looking for a guide how to import FSC 9C code with E-sys or any necessary software I might need. I have not yet bought any code, suggestions are wanted. My BMW-shop offer 6NR code for $ 233, but would not want to encode it because I have retrofitted my Combox. Can there be any problems when I have retrofitted a German Combox? I do not use the Combox-VIN, but changed to the Car-VIN (Sweden). Internet and Live works. 6NF USB-dock does not work, but I think it is because that there is no cable to CIC when all three video inputs are occupied with TV, DVD changer, Night Vision, Rear seat ent. Pro. I have changed production date from 0908 to 0312 in VO, för CMB_media and HU_CIC, if I change for all modules I got some errors (seatbelt and Fuel), is that normal? Thanks in advance :)
#159 ·
Hey guys I need a quick response. I took my car in for standard oil service and convinced them to do a software upgrade. Now they are claiming i'm at the latest software, is there anyone who can confirm? I'm pretty sure I'm not.
F010-14-03-502
Any idea's?
Thanks,
Josh
#161 ·
If your I-Step Current (not I-Step Shipment) is F010-14-03-502, there have been 4 newer versions since then:
F010-14-03-502
F010-14-03-503
F010-14-07-503
F010-14-07-504
F010-14-07-505
#160 ·
Disregard, dealer said they have an update and will let me know what it is shortly.
On another note I have a nice 535D loaner. Pretty fun and nice car. Too bad no manual was ever available.
#163 ·
If you have NBT, you would get iDrive 4.2 firmware. But, you would not get iDrive 4.2 Coding unless you VO Code NBT afterwards with >= 0713 build date.
#167 ·
Hi! I have a F31, my vin is f832726.... anyone can tell me if I can add 6nr?? I'm a bit confused with this ****!. If the answer is YES, any contact to provide me the 9c fsc code??
thanks
JP
Your car has 606 Business Navigation instead of 609 Professional Navigaiton. I do not know if BMW Apps will work for it.
#174 · (Edited)
"Hi Shawn, just read through all the posts and am very impressed with what you are doing here. Cheers..
I'm from Australia and BMW Apps (6NR) is not a factory option here (well at least for e84 X1). Hence, BMW AU won't do this retrofit. Came across Bimmer Retrofit but the amount they are asking is quite a lot than your source. So, I'm wondering if that price from your source is for OEM retrofit only (meaning those vehicles who could factory fit the option through dealer as well). And the ultimate question is, would those FSC codes work for me as well? :)
After going through all the posts here I had the impression that importing fsc codes using e-sys is not too hard. Would it be any different in my case? Do I need to do anything extra to activate apart from just importing fsc codes?
Are these fsc codes reusable? Like ECU coding can I set them back to the initial state and have them back when needed? This is so that BMW Service don't notice this so that I won't be in trouble ;) coz I'm just 6 mths into my 3 yrs warranty & 4 yrs free servicing.
Thanks in advance.."
Sorry for the double post I don't know how this happened :(
#177 ·
The 6NR FSC Code is OEM, as in ordered from and issued by BMW AG for your VIN. If you have CIC and Combox, there is no reason it would not work for you.
Since you have Exx car, Importing and Activating is more difficult for you. You need a copy FSTool, which is near impossible to find, and difficult to use if you can, so your best bet is using ISTA/P, or having someone with FSTool do it remotely for you.
It is not reusable. Once it is imported in the Head Unit, it is there forever.
#175 ·
Thanks in advance..
#180 ·
Oh ok.. so does that mean I could get the fsc codes of your source and if I could find a way to import them I could use them fine? If so plz PM me their details will ask them if they do remote importation/activation as well coz official ISTA/P licence download price is insensible for personal use. Also, is there a way to code them so that BMW service can't get them wiped out? BTW, I have 6NS base plate so do I have any chance that I already have video capability? I don't have 6NF though. These 6NF, 6NH, 6NS etc etc options are making me scratch my brains out.. should you require my vin is vx38204. Thanks heaps..
#181 ·
First see if you can get the FSC Code. If so, Apps can be coded to work PM sent.
FSC Code source will not do any work on your car though.
If you get FSC Code, contact user cn555ic:
https://www.bimmerfest.com/forums/member.php?u=270700
He can do this remotely on Exx car for you.
Your base plate will not have analog video connection. BMW added the FBAS Video Lines from the Base Plate to the CIC only when 6NR was added to the build sheet.
#186 · (Edited)
How about then get the 6NR fsc codes frm your source then buy 6NF base plate separately and have them remotely imported/activated? USB/AV in the armrest requires cutting to make place coz X1 has USB/AUX in the dashboard underneath radio and not in the centre armrest. Bimmer retrofit also confirmed that for me even the USB/AV option will only play iPhone videos. I just want to retain OEM look without any cables hanging around :) I didn't like this idea and this way BMW service as well won't be able to tell straight away tat there's sth fishy going on :)
#188 ·
Then I guess for now I'll be better off buying a portable CD/DVD drive to convert videos to DVD in my Surface Pro rather than a 6NR/6NF retrofit :( Maybe after warranty expires then look into retrofitting what will be available then..
Also, I was told that depending on how BMW wipes the fsc code it could be not as easy to import fsc codes later. Is there possibility for them to make it impossible to re-import again?
#201 ·
What I would have to do to get 6NR in my 2011 f25 with navi pro and combox? (11/2011)
I believe this thread already explains it all, but in summary, BMW Apps requires adding 6NR to VO, obtaining a 9C FSC Code issued by BMW AG for your VIN, Importing and Activating the FSC Code in Head Unit, and Coding, all of which can be done with E-Sys. With CiC, you will get all of BMW Apps except you will still not have Video and iPod out GUI functions as there is no FBAS Video Connection from the 6NF Base Plate if present nor the Center Armrest USB Port to back of CIC.
#205 ·
What you ask is already explained in this very thread.
See my Post #7 regarding FSC Import and Activation:
http://www.bimmerfest.com/forums/showpost.php?p=7645433&postcount=7
And as I wrote above, you only need to add hardware if you want Video / iPod Out function, as that requires FBAS Video lines run from 6NF Baseplate or modification of the 6FL USB Port.
#207 ·
HU_NBT => VOLUME_POPUP_DISPLAY = aktiv
But how is that relevant to the subject of this thread "All BMWs Guide for, how to import FSC 9C code, 6NR"? :dunno:
#209 ·
Guys
Sorry if I missed this but a question.
I have F010-11-03-510 i level on my CIC. It allowed me to activate 6NR without FSC code.
However, I have updated the whole car and wondering if there is a way to generate FSC code for 6NR or get it without spending silly prices just to update CIC.
It will be very illogical for me to update CIC and then spend good amount of money to have bmw applications?
or Shall I forget updating CIC?
#210 ·
Guys
Because you have F10, only clever options are:
1. Don't update CIC
2. Update CIC and buy 9C FSC-code that costs a bit under 200 euros.
