Guide for, how to import FSC 9C code, 6NR
127K views 404 replies 111 participants last post by  shawnsheridan
#1 ·
I'm looking for a guide how to import FSC 9C code with E-sys or any necessary software I might need. I have not yet bought any code, suggestions are wanted. My BMW-shop offer 6NR code for $ 233, but would not want to encode it because I have retrofitted my Combox. Can there be any problems when I have retrofitted a German Combox? I do not use the Combox-VIN, but changed to the Car-VIN (Sweden). Internet and Live works. 6NF USB-dock does not work, but I think it is because that there is no cable to CIC when all three video inputs are occupied with TV, DVD changer, Night Vision, Rear seat ent. Pro. I have changed production date from 0908 to 0312 in VO, för CMB_media and HU_CIC, if I change for all modules I got some errors (seatbelt and Fuel), is that normal? Thanks in advance :)
#314 ·
Hi Thorsten
I am sorry if I didn't make myself clear. I would like to purchase 6NR BMW apps. I don't have it yet hence, i can't see what apps are working or not.
Of course, I installed the bmw connected app on my android phone but it did not detect the car because the usb-to-phone interface is not enabled. 6NR will enable it. The app on itself doesn't do anything unless the usb connection is active. It only shows icons for Tweeter, Eco-pro and Wiki.
Thorsten, could you please share your experience with your android phone connected to the car? What apps are working? Did you get Spotify/Tunein to work?
Did anybody manage to get those apps working with an android phone?
#331 ·
6NR and voice recognition
Hi
Is it possible to retrofit 6NR and basic voice recognition of my F11 Europe version prod date 2011-01 with 6NF and 6FL? If yesyes, is it easy to do that? I have some basic coding skills, I did some changes like DVD in motion etc. I have researched a lot to retrofit 6NR but not sure about all the steps.
And FSC code how dodo I get it if I need some?
Thanks in advance
Kamran
#335 · (Edited)
E91 ISTAP import 9C
Hi, I would like to import 9C FSC into my E91 with ISTAp but with no luck.
thats what I have done:
1. Retrofit Combox+Snap in, change FA date from 0609 to 0311, code CIC/media, FA back to 0609 - all works perfect, exept i can use ISTAP with combox connected because it ask me to replace TEL/ULF and ULF-SBX.
2. ordered 9C FSC and recieved zip with 4 files inside (der, fsc,xml,fsc)
3. disconnect combox from Most remove all VO about combox and leave just 6NR, code CIC.
4. use guide* for import with ISTAP, so I can see FSC in import tab in ista.
5. Program/code CIC.
but looks like it not import FSC into car. I still see juts old codes like 17,19,1B and 28 but no 9C.
What am I doing wrong?
My integraftion level is E89X-15-11-500. Im using prety new ICOM ABC clone with last FW. Istap is on Windows 8 prety powerfull laptop.
FSC is from Patryk.
* I cant insert hyperlink for this guide so try to google "use ista p to import an enabling code fsc"
#336 ·
Hi, I would like to import 9C FSC into my E91 with ISTAp but with no luck...
Not sure why, but I never see this work with ISTA/P. Only way it works that I have seen is using FSTool, and newer version at that, as older version do not support 9C FSC Code,.
#340 ·
Guys, i have the same problem here, i have got the FStool V2, but i am not familiar of the connection methods, how to make it connect to the car CIC? please help
i have ICOM using CIC special utility is shows all FSC are rejected, i have ordered the full FSC repaid kit, just want to inject it
#354 ·
Hallo
Now i have read all the pages and if i undertand all right i need to use fstool or ISTA/P ?
to import the 9c code.
Is there a way to test if my FStool works right before buying 9c code.
and can i use one of these Cabels ? i already have ?
MaxDia Diag 2+ - Diagnose Interface fĂĽr BMW-Fahrzeuge(Bj. 2007 - 2016)
MaxDia ENET V2 - Ethernet Interface fĂĽr BMW F- und G-Modelle
Can i get the connectdrive apps when i only have a E91 and with Navigation Business?
I have already change the FA im CAS und NFRM so that i could use
bluetooth tethering over handy. i have use my own VIN.
Delete
$606(Wenn du einen Naiv Business hattest)
$612
$619
Gib bei Attribute und jedes mal mit "Add" bestätigen
$609
$614
$615 (Ist Vorhanden)
$616 (Ist Vorhanden)
$620
$633 (Ist Vorhanden)
$6VA
$6VC (Ist Vorhanden)
$6FL (Ist Vorhanden)
$6NF (Ist Vorhanden)
&6NR
$6AA (Ist Vorhanden)
$6AB (Ist Vorhanden)
#355 ·
No. If you have CHAMP2 or CIC-MID Head Unit, you cannot have BMW Apps.
#360 ·
.bin is generally for retrofits, not factory fitted head unit as it replaces all OEM FSC Codes with non-OEM (fake) FSC codes, and it is only possible for NBT / NBT2 and not CIC.
PM sent.
Hi,
I would love a PM for BMW apps for a CIC equipped F30.
PM sent.
