141 - 160 of 405 Posts
@Shawn, just please a question - I have flashed my car completely with Esys and Enet going from F025-11-03-512 to F025-14-03-504. Just a big jump:p
Ofcourse I expected that I will loose 6NR function when leaving Ista 42.x (free). I have a 6NR FSC from another car for another VIN and I cant put him into CIC, by normal method (Upgrade FSC or Write FSC). Yes I changed VIN in CIC to match VIN of FSC in order to get him in. I know that if I will get him in, he will be rejected, but it is not problem.:)
Do you have any other "Shawns magic" how to get him into CIC ?
1) You can't just add 6NR from another VIN, you need a complete set of FSC Codes. They can't be mixed VIN.
2) What is the error you get while Importing? Is it a creation date error?
Thank you I will check with esys this weekend. I do have 6AM real-time traffic.
Do you know what firmware we need to be at for the voice button to operate siri or samsung S? I can see texts but not respond.
Regarding the bluetooth, I'm confused because this is whats in the readme:
TN-2.34.1
***9655; MN-2.18.2, TN-2.18.5
***9655; MN-1.37.3, TN-1.37.10
***9655; MN-1.23.7, TN-1.23.15
***9655; MN-1.21.6, TN-1.21.15
And my car says
MN-002.038.015
TN- 002.038.015
So does that put me ahead or behind since I have 3 digits per section.
I wrote above "NBT needs at least ISTA/P 2.50.4 firmware, which is I-Step F010-13-07-506".
It is possible that your Bluetooth software is newer than the UPD05021.bin version. What is available on BMW Update site seems to lag that which is in ISTA/P.
Hi Shawn
Could you please send me your contact to the 6NR FSC?
Thx
Does your car have Option 6AM Real-Time Traffic Information?
NBT had a bunch of updates beginning with 0713 builds. Android Support, SIRI Support, Volume Overlay, to name a few. If I remember right, NBT needs at least ISTA/P 2.50.4 firmware, which is I-Step F010-13-07-506. You can check your I-Step as follows:
http://f30.bimmerpost.com/forums/showpost.php?p=13159662&postcount=1403
If you cant convince your dealer to program your car, you can flash NBT with E-Sys, PSdZData Full version, and ENET Cable. You will need to put the car on a commercial grade charger, good for 50 amps or more.
As for Bluetooth Update, the readme file from bmw.com/update will state what the latest TX/MX versions are. If you have those same versions, then you are current. If you do not have those versions, and performing the USB Update does not take you to those versions, then you are being held back by the NBT Firmware.
This is old but I finally got around to checking please see screen shot. I assume this means I have F010-14-03-502 which appears to be newer so I'm confused.
Thanks,
Josh
Yes, yours is newer.
Thanks so if thats the case what do I need to do to make Android support and push to call siri so Samsung S to work? Is there still newer code I should ask my dealer for since I'm going in for service next month? I want to make sure I have the latest code for the steering too.
Thanks and happy labor day,
Josh
Josh
Your dealer needs to program your car with latest ISTA/P, then when you get it back, depending on car build date, Siri and Android support will already be working, or you will have to code it.
Thanks I will update when its done.
Do I need to change my production date via coding or should it just work with software.
If it comes back not working, then I would just leave FA Production date alone, and FDL Code NBT as follows:
CE_DEVICE_SPEECH_RECOGNITION = aktiv
A4A_ANDROID= aktiv
well that's interesting. UPD5021 broke some bluetooth stuff for me that's really annoying.
not sure i want to start messing with stuff in NBT though as i have all the options already and i'd like for them to still work. shame BMW.com/update can't stay up to date though :/
Thanks,
Josh
Hey guys I need a quick response. I took my car in for standard oil service and convinced them to do a software upgrade. Now they are claiming i'm at the latest software, is there anyone who can confirm? I'm pretty sure I'm not.
F010-14-03-502
Any idea's?
Thanks,
Josh
Disregard, dealer said they have an update and will let me know what it is shortly.
On another note I have a nice 535D loaner. Pretty fun and nice car. Too bad no manual was ever available.
