I***8217;ve got an 09 BMW 328i. I have no mods and nothing done to it besides coding done with the Carly OBD 2 adapter.
I was driving regularly after getting gas when I got a service engine soon light (yellow) a few weeks ago, when I was driving it was surging power and sputtering while driving. Took it home and left it for a few days and it wouldn***8217;t start (it will crank but not turn over fully) it***8217;ll turn over like it***8217;s almost there but won***8217;t start.
It still won***8217;t start after that, I ran some codes with my adapter and it gave me mixture control issues along with EWS4 timing chall error which I thought was my O2 sensors and for some reason the anti theft kicked it, I later figured out my battery had a dead cell so I replaced it, cleared the codes and they didn***8217;t pop up again.
Now it***8217;s giving me dynamic stability control codes and DME (which I think is the chip that helps regulates fuel). I had looked on a ton of forums and have cleaned my vanos solenoid and mass air flow sensor think they could be the fix, I don***8217;t think my spark plugs and ignition coils are the problem but I***8217;m not sure since I haven***8217;t pulled them out to check. I***8217;m at a real loss on what the problem is, i talked to some friends and online on more bmw forums for situations like mine and I***8217;ve gathered that I should run a fuel pump pressure test and go from there.
I***8217;m at a real loss on what to do here
ERROR CODES PROVIDED BY CARLY OBD II:
006EC4 - Steering Sensor Angle
00A559 - :KL30g f Cutoff
00ABEC - Error Connection to radio drive
00A8B6 - Left Brake Light Is Defective
00A8A9 - High Beam and Conerning Broken
009CD0 - Folded Passenger Side Mirror Defect
009CCF - Driver Side Folded Passenger Mirror Defect
