1 - 9 of 9 Posts
So Im Buying Lowering Springs This Weekend, And I Have Done Hella Research On The Matter And Finally Decided To Go With H&R, But I Can Not Make Up My Mind Between The Race Or Sport Springs... I Really Want The More Slammed Look So I'm Most Likely Going To Go With The Race Springs That Will Drop My Car The Full 2 Inchs Instead Of The 1.4-1.6 With The Sport Springs...
Right Now My Car Is Sitting On 225-50-17 Stock Rims And I Want To Know If Anyone Has Put Race Springs On A 528i And Have They Had Any Issues With Rubbing Or Did They Have To Do A Fender Roll, What Spacers They Got Away With Without Issues, Etc... Etc...
I Have Style 5 BBS Rims From The Old 5er Im Restoring Currently That Are The Same Size As My Current Stock So I Plan To FlipFlop Rims When I Drop So Tire Size Wont Change...
I Have Read From Many That The Sport Springs Don't Even Need A Fender Roll And People Run 15mm Spacers Front & Back No Issues, But When I Look For Info On The Race Springs, I Cant Find Much About People Running Them Or Any Issues They Had...
I assume you have 8j rim width which will not be an issue with rubbing. Also, what's the offset on the rims you are restoring. This info is crucial to making a decision on spacer size.
Sent from my SAMSUNG-SM-J120A using Bimmerfest mobile app
Banned
lowering springs ride like ****, you clearly havent done enough research if you have decided to buy lowering springs. unless your car has the lowered sport suspension from the factory i do not recommend it. look into the bilstein b12 kit, fortune auto coilovers, ohlins, BC racing, KW, etc.
Discussion Starter · #4 · (Edited)
Thank You EtherGhost Thats Exactly What I Wanted To Hear... I Do Currently Have 8J but I will Be Installing E39 BBS RC090 17x8 +20mm
& Str8 Six I Wish I Could Afford Coils Right Now But My Pockets Are Tight, I Just Got My Car Back From The Shop, Replaced The Tranny For $4700 at 101k :mad: & I Don't Have Sport Suspension But Have Konis Installed At 90k
Banned
Thank You EtherGhost Thats Exactly What I Wanted To Hear... I Do Currently Have 8Js but I will Be Installing E36 BBS RC090 17x8 +20mm
Oh so then youre good, you dont need coilovers. I recommend eibach springs over H&R though. The drop is not as aggressive but the car will ride better.
Sorry to hear about the tranny... About the look of the car... Are you aiming for flush look?
Discussion Starter · #7 ·
Any Reasons Why In Particular, I Read The Eibachs Give The Car A More Raked Look, The H&R Race Springs Looked Like The Biggest Drop I Could Find From Springs Without Going To Coils...
Discussion Starter · #9 · (Edited)
So I Just Pulled The Trigger On The H&R Race Springs, :roundel: Should Be Here By Next Wednesday...
Any Opinions On What Spacer Size I Should Run With Those BBS Rims They Are +20
1 - 9 of 9 Posts
